How can I define the order of module initilations with PE?
mikijt
Hi  :
in CW the order of module initilations seem to be constant,how can i change it?
MiKi
FelipeGarcia
Hi MiKi,
You can change the order in the Initialization Sequence view. To open this view, click Window > Show View > Other... and select ProcessorExpert > Initialization Sequence.
I hope this helps.
Felipe
mikijt
Thank you very much
