HELP!!!questions about freemaster!!!
2,682 次查看
nietongnie
can not detect the board information ! The communication will be paused .
Error code:0x848c0010(could not transmit CAN/LIN frame.)
I use freemaster through CAN.What should I do? Help!
标记 (1)
4 回复数
2,315 次查看
ivadorazinova
please, do you have correctly set communication?
What is your MCU?
Iva
2,315 次查看
nietongnie
MC56F84789
2,315 次查看
nietongnie
this is my first time to set this module with PE,so I don't know how to use it.My MCU is MC56F84789.Would you tell me how to set communication with PE about freemaster module through CAN on this MCU?Thank you very much!
2,315 次查看
ivadorazinova
It is needed to add CAN module.
please can you check this thread?
https://community.nxp.com/thread/381978
I hope this helps.
Iva
