HCS12EX, CW 4.7, CAN bean bit rate wizard: Is it stable?
1,503 次查看
AndersJ
The bit rate timing wizard seems unstable, producing inconsistent results.
The suggested prescaler settings varies from time to time.
I can't put my finger on the issue, it just feels weird.
Does the wizard have problems?
Anders J
1,406 次查看
ZhangJennie
I use CW5.1 and CW5.2, we didn't have this problem.
can you please try it with the latest CW5.2?
CodeWarrior Dev Tools for HCS12(X) MCUs|NXP
if the problem persists. please send:
1. your demo project.
2. describe how to reproduce your problem with your project step by step, thanks!
Jennie Zhang
1,407 次查看
ZhangJennie
Jennie Zhang
