From codewarrior to hardware
1,081件の閲覧回数
tianzc
I'm using CW_VSPA_v10.3.10. After successfully debugging my code, I don't know how to deploy it to the hardware. The board I'm using is LA1224. I noticed that all the example files include both .eld and .map files, but only the .eld file is generated in my project.
4 返答(返信)
1,067件の閲覧回数
yipingwang
Deploying your code to the LA1224 board
There are two common deployment paths, depending on whether you want RAM loading or persistent Flash loading.
Option A: Load directly to hardware using the debugger (most common during development)
This is usually what you already did when debugging.
Steps:
  1. Connect the LA1224 board (JTAG / probe / USB as required)
  2. In CW_VSPA:
    Run → Debug Configurations
  3. Select your VSPA / LA1224 debug configuration
  4. Make sure:
    • The .eld file from your project is selected
  5. Click Debug
This already deploys your code into target RAM
It is not persistent (power cycle clears it)
Option B: Program the code into Flash (standalone operation)
If you want the LA1224 to boot your application automatically after reset:
Typical process:
  1. Build the project → obtain .eld
  2. Use the LA1224 Flash programming tool (varies by board support package):
    • Often launched from CW_VSPA:
      Tools → Flash Programmer
      or
      Run → External Tools
  3. Select:
    • Target: LA1224
    • Input file: your .eld
  4. Program to Flash
  5. Reset or power-cycle the board
Code now runs without debugger
.map file is irrelevant here
192件の閲覧回数
flappy
Hi, I'm having the same problem. I'm using CodeWarrior for VSPA 10.3.10, but I don't see the “Tools - Flash Programmer” option there.
Under “Target Tasks,” the only options are “Import/Export/Fill Memory” and “HW Diagnostics.”
How can I program the VSPA image to the flash memory?
For the E200, I use the Flash Programmer from CWforARM. I successfully flash *xspi.bin with an offset of 0x0.
133件の閲覧回数
flappy
954件の閲覧回数
tianzc
Thank you. But I'm still wondering whether I can deploy my codes by using codewarrior Tap and how to use it. I tried to write a script but failed, so are there any examples or instructions that can tell me how to write a script?
%3CLINGO-SUB%20id%3D%22lingo-sub-2355538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%B3%E3%83%BC%E3%83%89%E6%88%A6%E5%A3%AB%E3%81%8B%E3%82%89%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFCW_VSPA_v10.3.10%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFLA1224%E3%81%A7%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%20.eld%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8A%E3%82%88%E3%81%B3%20.map%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E3%81%9F%E3%81%A0%E3%81%97.eld%E3%81%AE%E3%81%BF%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%86%85%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CodeWarrior%20Tap%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%9D%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E6%9B%B8%E3%81%8D%E6%96%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E4%BE%8B%E3%82%84%E6%89%8B%E9%A0%86%E6%9B%B8%E3%81%AA%E3%81%A9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--466932819%22%20id%3D%22toc-hId--466873387%22%20id%3D%22toc-hId--466873387%22%3ELA1224%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%3C%2FH2%3E%0A%3CP%3ERAM%E3%81%B8%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8B%E3%80%81%E6%B0%B8%E7%B6%9A%E7%9A%84%E3%81%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%81%3CSTRONG%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E6%96%B9%E6%B3%95%E3%81%AF2%E3%81%A4%3C%2FSTRONG%3E%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-223628655%22%20id%3D%22toc-hId-223688087%22%20id%3D%22toc-hId-223688087%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3A%EF%BC%9A%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%EF%BC%88%E9%96%8B%E7%99%BA%E6%99%82%E3%81%AB%E6%9C%80%E3%82%82%E3%82%88%E3%81%8F%E7%94%A8%E3%81%84%E3%82%89%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%EF%BC%89%3C%2FH3%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%99%82%E3%81%AB%E6%97%A2%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-914190129%22%20id%3D%22toc-hId-914249561%22%20id%3D%22toc-hId-914249561%22%3E%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3ELA1224%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6JTAG%2F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%2FUSB%E6%8E%A5%E7%B6%9A%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3ECW_VSPA%E3%81%A7%E3%81%AF%EF%BC%9A%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ERun%20%E2%86%92%20Debug%20Configurations%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EVSPA%20%2F%20LA1224%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLI%3E%0A%3CLI%3E%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%3CSTRONG%3E.eld%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSTRONG%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%3CEM%3E%E3%80%81%E6%97%A2%E3%81%AB%3C%2FEM%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AERAM%3C%2FSTRONG%3E%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%3CSTRONG%3E%E6%B0%B8%E7%B6%9A%E7%9A%84%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%EF%BC%88%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%99%E3%81%A8%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CHR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-903687025%22%20id%3D%22toc-hId-903746457%22%20id%3D%22toc-hId-903746457%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3B%EF%BC%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92Flash%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%EF%BC%88%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E5%8B%95%E4%BD%9C%EF%BC%89%3C%2FH3%3E%0A%3CP%3ELA1224%E3%82%92%3CSTRONG%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%3C%2FSTRONG%3E%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1594248499%22%20id%3D%22toc-hId-1594307931%22%20id%3D%22toc-hId-1594307931%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%EF%BC%9A%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%A7%8B%E7%AF%89%20%E2%86%92%20%E5%8F%96%E5%BE%97%20%3CCODE%20translate%3D%22no%22%3E.eld%3C%2FCODE%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3ELA1224%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%84%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%0A%3CUL%3E%0A%3CLI%3ECW_VSPA%E3%81%8B%E3%82%89%E3%82%88%E3%81%8F%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%82%8B%EF%BC%9A%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ETools%20%E2%86%92%20Flash%20Programmer%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%E3%81%BE%E3%81%9F%E3%81%AF%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ERun%20%E2%86%92%20External%20Tools%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E9%81%B8%E6%8A%9E%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3A%20%3CSTRONG%3ELA1224%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E5%85%A5%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%3CSTRONG%3E%3CCODE%20translate%3D%22no%22%3E.eld%3C%2FCODE%3E%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FLI%3E%0A%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%3CCODE%20translate%3D%22no%22%3E.map%3C%2FCODE%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFVSPA%2010.3.10%E7%94%A8%E3%81%AECodeWarrior%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C%E3%83%84%E3%83%BC%E3%83%AB%20-%20Flash%20Programmer%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%80%8C%E5%AF%BE%E8%B1%A1%E3%82%BF%E3%82%B9%E3%82%AF%E3%80%8D%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%2F%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%2F%E3%83%95%E3%82%A3%E3%83%AB%E3%80%8D%E3%81%A8%E3%80%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%BA%E6%96%AD%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EVSPA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3EE200%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%A7%81%E3%81%AFCWforARM%E3%81%AEFlash%20Programmer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x0%E3%81%A7*xspi.bin%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E
