From codewarrior to hardware
1,158 次查看
tianzc
I'm using CW_VSPA_v10.3.10. After successfully debugging my code, I don't know how to deploy it to the hardware. The board I'm using is LA1224. I noticed that all the example files include both .eld and .map files, but only the .eld file is generated in my project.
4 回复数
1,144 次查看
yipingwang
Deploying your code to the LA1224 board
There are two common deployment paths, depending on whether you want RAM loading or persistent Flash loading.
Option A: Load directly to hardware using the debugger (most common during development)
This is usually what you already did when debugging.
Steps:
  1. Connect the LA1224 board (JTAG / probe / USB as required)
  2. In CW_VSPA:
    Run → Debug Configurations
  3. Select your VSPA / LA1224 debug configuration
  4. Make sure:
    • The .eld file from your project is selected
  5. Click Debug
This already deploys your code into target RAM
It is not persistent (power cycle clears it)
Option B: Program the code into Flash (standalone operation)
If you want the LA1224 to boot your application automatically after reset:
Typical process:
  1. Build the project → obtain .eld
  2. Use the LA1224 Flash programming tool (varies by board support package):
    • Often launched from CW_VSPA:
      Tools → Flash Programmer
      or
      Run → External Tools
  3. Select:
    • Target: LA1224
    • Input file: your .eld
  4. Program to Flash
  5. Reset or power-cycle the board
Code now runs without debugger
.map file is irrelevant here
269 次查看
flappy
Hi, I'm having the same problem. I'm using CodeWarrior for VSPA 10.3.10, but I don't see the “Tools - Flash Programmer” option there.
Under “Target Tasks,” the only options are “Import/Export/Fill Memory” and “HW Diagnostics.”
How can I program the VSPA image to the flash memory?
For the E200, I use the Flash Programmer from CWforARM. I successfully flash *xspi.bin with an offset of 0x0.
210 次查看
flappy
1,031 次查看
tianzc
Thank you. But I'm still wondering whether I can deploy my codes by using codewarrior Tap and how to use it. I tried to write a script but failed, so are there any examples or instructions that can tell me how to write a script?
%3CLINGO-SUB%20id%3D%22lingo-sub-2355538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8E%E5%AF%86%E7%A0%81%E6%88%98%E5%A3%AB%E5%88%B0%E7%A1%AC%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20CW_VSPA_v10.3.10%E3%80%82%E6%88%90%E5%8A%9F%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%E5%90%8E%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%E5%85%B6%E9%83%A8%E7%BD%B2%E5%88%B0%E7%A1%AC%E4%BB%B6%E4%B8%8A%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%20LA1224%E3%80%82%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E6%89%80%E6%9C%89%E7%A4%BA%E4%BE%8B%E6%96%87%E4%BB%B6%E9%83%BD%E5%8C%85%E5%90%AB%20.eld%E5%92%8C%20.map%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E5%8F%AA%E6%9C%89%20.eld%E6%96%87%E4%BB%B6%E5%B7%B2%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%94%9F%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%20codewarrior%20Tap%20%E6%9D%A5%E9%83%A8%E7%BD%B2%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E7%BC%96%E5%86%99%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BE%8B%E5%AD%90%E6%88%96%E8%AF%B4%E6%98%8E%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E7%BC%96%E5%86%99%E8%84%9A%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--466932819%22%20id%3D%22toc-hId--466873352%22%20id%3D%22toc-hId--466873352%22%3E%E5%B0%86%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E9%83%A8%E7%BD%B2%E5%88%B0%20LA1224%20%E6%9D%BF%E4%B8%8A%3C%2FH2%3E%0A%3CP%3E%E6%9C%89%3CSTRONG%3E%E4%B8%A4%E7%A7%8D%E5%B8%B8%E8%A7%81%E7%9A%84%E9%83%A8%E7%BD%B2%E8%B7%AF%E5%BE%84%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%96%E5%86%B3%E4%BA%8E%E4%BD%A0%E6%98%AF%E6%83%B3%E8%A6%81%20RAM%20%E5%8A%A0%E8%BD%BD%E8%BF%98%E6%98%AF%E6%8C%81%E4%B9%85%E9%97%AA%E5%AD%98%E5%8A%A0%E8%BD%BD%E3%80%82%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-223628655%22%20id%3D%22toc-hId-223688122%22%20id%3D%22toc-hId-223688122%22%3E%E9%80%89%E9%A1%B9%20A%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%E5%88%B0%E7%A1%AC%E4%BB%B6%EF%BC%88%E5%9C%A8%E5%BC%80%E5%8F%91%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%9C%80%E5%B8%B8%E8%A7%81%EF%BC%89%3C%2FH3%3E%0A%3CP%3E%E8%BF%99%E9%80%9A%E5%B8%B8%E6%98%AF%E6%82%A8%E5%9C%A8%E8%B0%83%E8%AF%95%E6%97%B6%E5%B7%B2%E7%BB%8F%E5%81%9A%E8%BF%87%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-914190129%22%20id%3D%22toc-hId-914249596%22%20id%3D%22toc-hId-914249596%22%3E%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%E8%BF%9E%E6%8E%A5%20%3CSTRONG%3ELA1224%20%E6%9D%BF%3C%2FSTRONG%3E%EF%BC%88%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%20JTAG%2Fprobe%2FUSB%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%20CW_VSPA%20%E4%B8%AD%EF%BC%9A%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ERun%20%E2%86%92%20Debug%20Configurations%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E9%80%89%E6%8B%A9%E6%82%A8%E7%9A%84%3CSTRONG%3EVSPA%20%2F%20LA1224%20%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E7%A1%AE%E4%BF%9D%0A%3CUL%3E%0A%3CLI%3E%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%3CSTRONG%3E.eld%20%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E7%82%B9%E5%87%BB%20%3CSTRONG%3E%E2%80%9CDebug%E2%80%9D%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E8%BF%99%3CEM%3E%E5%B7%B2%E5%B0%86%3C%2FEM%3E%E4%BB%A3%E7%A0%81%E9%83%A8%E7%BD%B2%E5%88%B0%3CSTRONG%3E%E7%9B%AE%E6%A0%87%20RAM%3C%2FSTRONG%3E%E4%B8%AD%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%AE%83%3CSTRONG%3E%E4%B8%8D%E6%98%AF%E6%8C%81%E4%B9%85%E6%80%A7%E7%9A%84%3C%2FSTRONG%3E%EF%BC%88%E7%94%B5%E6%BA%90%E5%BE%AA%E7%8E%AF%E4%BC%9A%E6%B8%85%E9%99%A4%E5%AE%83%EF%BC%89%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CHR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-903687025%22%20id%3D%22toc-hId-903746492%22%20id%3D%22toc-hId-903746492%22%3E%E9%80%89%E9%A1%B9%20B%EF%BC%9A%E5%B0%86%E4%BB%A3%E7%A0%81%E7%BC%96%E7%A8%8B%E5%88%B0%20Flash%20%E4%B8%AD%EF%BC%88%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20(SA)%20%E6%93%8D%E4%BD%9C%EF%BC%89%3C%2FH3%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%B8%8C%E6%9C%9B%20LA1224%20%E5%9C%A8%3CSTRONG%3ERESET%E5%90%8E%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1594248499%22%20id%3D%22toc-hId-1594307966%22%20id%3D%22toc-hId-1594307966%22%3E%E5%85%B8%E5%9E%8B%E6%B5%81%E7%A8%8B%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%E7%94%9F%E6%88%90%E9%A1%B9%E7%9B%AE%20%E2%86%92%20%E8%8E%B7%E5%8F%96%20%3CCODE%20translate%3D%22no%22%3E.eld%3C%2FCODE%3E%3C%2FLI%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20%3CSTRONG%3ELA1224%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%EF%BC%88%E5%9B%A0%E4%B8%BB%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E8%80%8C%E5%BC%82%EF%BC%89%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E9%80%9A%E5%B8%B8%E4%BB%8E%20CW_VSPA%20%E5%90%AF%E5%8A%A8%EF%BC%9A%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ETools%20%E2%86%92%20Flash%20Programmer%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%E6%88%96%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3ERun%20%E2%86%92%20External%20Tools%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E8%AF%B7%E9%80%89%E6%8B%A9%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E7%9B%AE%E6%A0%87%EF%BC%9A%20LA1224%3CSTRONG%3ELA1224%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E8%BE%93%E5%85%A5%E6%96%87%E4%BB%B6%EF%BC%9A%E6%82%A8%E7%9A%84%20%3CSTRONG%3E%3CCODE%20translate%3D%22no%22%3E.eld%3C%2FCODE%3E%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E7%BC%96%E7%A8%8B%E8%87%B3%E9%97%AA%E5%AD%98%3C%2FLI%3E%0A%3CLI%3ERESET%E4%B8%BB%E6%9D%BF%E6%88%96%E9%87%8D%E6%96%B0%E9%80%9A%E7%94%B5%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E4%BB%A3%E7%A0%81%E7%8E%B0%E5%9C%A8%E6%97%A0%E9%9C%80%E8%B0%83%E8%AF%95%E5%99%A8%E5%8D%B3%E5%8F%AF%E8%BF%90%E8%A1%8C%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%3CCODE%20translate%3D%22no%22%3E.map%3C%2FCODE%3E%20%E6%96%87%E4%BB%B6%E4%B8%8E%E6%AD%A4%E5%A4%84%E6%97%A0%E5%85%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20From%20codewarrior%20to%20hardware%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20CodeWarrior%20for%20VSPA%2010.3.10%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%E9%82%A3%E9%87%8C%E7%9C%8B%E5%88%B0%E2%80%9C%E5%B7%A5%E5%85%B7%20-%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E2%80%9D%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E2%80%9C%E7%9B%AE%E6%A0%87%E4%BB%BB%E5%8A%A1%E2%80%9D%E4%B8%8B%EF%BC%8C%E5%8F%AA%E6%9C%89%E2%80%9C%E5%AF%BC%E5%85%A5%2F%E5%AF%BC%E5%87%BA%2F%E5%A1%AB%E5%85%85%E5%86%85%E5%AD%98%E2%80%9D%E5%92%8C%E2%80%9C%E7%A1%AC%E4%BB%B6%E8%AF%8A%E6%96%AD%E2%80%9D%E8%BF%99%E4%B8%A4%E4%B8%AA%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E4%BD%95%E5%B0%86VSPA%E9%95%9C%E5%83%8F%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%20E200%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20CWforARM%20%E7%9A%84%20Flash%20Programmer%E3%80%82%E6%88%91%E5%B7%B2%E6%88%90%E5%8A%9F%E5%B0%86%E5%81%8F%E7%A7%BB%E9%87%8F%E4%B8%BA%200x0%20%E7%9A%84%20*xspi.bin%20%E6%96%87%E4%BB%B6%E5%88%B7%E5%85%A5%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FLINGO-BODY%3E
