Error when installing setup file for Code warrior
2,991 次查看
ngyb
Subject: Error when installing setup file for Code warrior
Description: I encountered a error when running the installation file for
CodeWarrior for Microcontrollers - Professional Edition version 6.3.
The error is cannot support 64 bit system. Is there any solution for this?
Please help to advise. Thanks
5 回复数
2,880 次查看
ZhangJennie
CW for MCU classic IDE v6.3 supports 32bit system only. It can't support 64bit system. We can see this limitation mentioned in its homepage, under "system requirements"
http://www.nxp.com/products/software-and-tools/software-development-tools/codewarrior-development-to...
If you use HCS08 device, I suggest you use CW10.7 instead. It supports 64bit system well.
Jennie Zhang
2,880 次查看
ngyb
Hi Jennie,
I found that I need to purchase 10.7 seperately (not part of my purchase
package)
Is there any workaround solution or is there any other version that can be
used for 64 bit windows?
Can the version 7.2 work?
Codewarrior Development Studio, ColdFire Professional Edition WIN
Please advise. Thanks
Best Regards
Yewbeng
ZhangJennie <[email protected]>
To:
NG Yew Beng/Asst Prin Engr-KDM/DBG/ST Kinetics@ST Engineering
Date:
Tue 23 May 2017 10:33 AM
Subject:
Re: - Re: Error when installing setup file
for Code warrior
NXP Community
Re: Error when installing setup file for Code warrior
reply from ZhangJennie in CodeWarrior Development Tools - View the full
discussion
http://www.nxp.com/products/software-and-tools/software-development-tools/codewarrior-development-to...?
64bit system well.
Jennie Zhang
2,880 次查看
ZhangJennie
Hi Ng,
Here is a workaround provided by our customer.
https://community.nxp.com/message/310577
You can refer it,  but officially NXP can't provide technical support for it.
Our official recommendation is to use CW10.x on 64bit win7.
Jennie Zhang
2,880 次查看
ngyb
Hi Jennie,
Best Regards
Yewbeng
To:
Date:
Tue 23 May 2017 03:07 PM
Subject:
for Code warrior
NXP Community
discussion
Hi Ng,
How-to Directly Install CodeWarrior 6.3 Classic in Windows 7 & 10 x64
(Unofficial Method)
it.
Jennie Zhang
2,880 次查看
ZhangJennie
You are welcome.
Jennie Zhang.
