Debug Failed
Debug Failed
6,881 次查看
jinliangsun
I use CW for MCU to debug program on DevKit-S12ZVC. It worked well until one day I can't debug the program step by step. I got the following information.
And here is the setup.
Actually if I try to debug the sample project, it works fine.
Can anybody help me? Thanks.
Bruce.
======== CW info ========
CodeWarrior for MCU
Version: 11.0.1
Build Id:180609
=== CodeWarrior GDI protocol log ===
GDI DLL: C:\Freescale\CW MCU v11.0\MCU\bin\Plugins\Debugger\protocols\..\..\support\s12z\gdi\s12z_pne_gdi.dll
CPU: MC9S12ZVCA192
GDI: DiGdiOpen()
GDI: => DI_OK
GDI: DiGdiGetFeatures()
GDI: => DI_OK
GDI: Identification: S12Z P&E to GDI wrapper, Version: 1.0.1, MeeAvailable: true, NrCpusAvailable: 1
GDI: DiGdiAddCallBack(cb_type = 0x4000)
GDI: => DI_OK
GDI: DiGdiInitIO()
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : , Entry : CWDBG_Simulator, Value : , R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_SETMEEID, 1) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : GENERAL, Entry : CORBA_IDENTIFIER0, Value : , R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : GENERAL, Entry : CORBA_IDENTIFIER1, Value : , R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : DO_DEBUG_OUTPUT, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : DEPENDENCY_CHECK, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : UUID, Value : DefaultProject, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : CWDBG, Entry : Processor, Value : MC9S12ZVCA192, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : ERASE_PROGRAM_WITHOUT_ASKING, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : AUTO_SYNC, Value : 1, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : DOTRIM, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : CURRENT_ALGORITHM_INDEX, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE1_START, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE1_END, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE1_ACTIVE, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE2_START, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE2_END, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE2_ACTIVE, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE3_START, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE3_END, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PRESERVE3_ACTIVE, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : MC9S12ZVCA192, Entry : PRESERVE_EEPROM_START, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : MC9S12ZVCA192, Entry : PRESERVE_EEPROM_END, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : MC9S12ZVCA192, Entry : PRESERVE_EEPROM, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : ALTERNATIVE_ALGORITHM_PATH, Value : , R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : ALTERNATIVE_ALGORITHM_CHECKBOX, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : PARTITION_PARAM, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : DO_PARTITIONING, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : CUSTOM_TRIM, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : MC9S12ZVCA192, Entry : TRIM_VALUE, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : NGS_TRIM_OVERRIDE_REFERENCE_FREQUENCY, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : ENABLE_FLASH_PROGRAMMING_DIALOG, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : SCRIPTFILE, Entry : RUN_RESET_SCRIPT_FILE, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : SCRIPTFILE, Entry : RESET_SCRIPT_FILE, Value : C:\Freescale\CW MCU v11.0\MCU\bin\Plugins\support\s12z\gdi\P&E\resetscript.mac, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : SCRIPTFILE, Entry : RESET_SCRIPT_FILE_RUN_MODE, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : SCRIPTFILE, Entry : NUM_EXTRA_USER_SCRIPTFILES, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : SPECIFY_NETWORKCARD_ENABLED, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : IO_DELAY_CNT, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP12, Entry : show_hstep_assembly_details_new, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : CWDBG, Entry : Connect, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : eclipse_show_connection_assistant, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_FX, Value : 4, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_NORMAL, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_OSJTAG, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_CYCLONE, Value : 3, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_TRACELINK, Value : 3, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_LIGHTNING, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : FREQ_OPENSDA, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : RESET_DELAY, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : PORT, Value : 21, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : PORT_NAME_STRING, Value : SER01, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : interface_selection, Value : 0, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : check_and_fix_if_secure_enable_flag, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : IO_DELAY_SET, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : USE_CYCLONEPRO_RELAYS, Value : 1, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : CyclonePro_poweroffonexit, Value : 1, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : CyclonePro_currentvoltage, Value : 255, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : CyclonePro_PowerDownDelay, Value : 250, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : CyclonePro_PowerUpDelay, Value : 250, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : Multilink_PowerUpDelay, Value : 1000, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : Multilink_PowerDownDelay, Value : 250, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : s12z_use_hw_breaks, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : set_CLKSW_bit_on_reset, Value : 1, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : icd_always_reset_on_startup, Value : 0, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : icd_continually_poll_device_status, Value : 1, R) => DI_ERR_NONFATAL
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : TraceLink_MaxBufferSize, Value : 1, R) => DI_OK
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : CPUTARGETTYPENAME, Value : , R) => DI_ERR_NONFATAL
INF: P&E Interface detected - Flash Version 31.26
INF: Device is MC9S12ZVCA192.
INF: Mode is In-Circuit Debug.
GDI: => DI_OK
GDI: DiMeeConnect(exec_env_id = 1)
GDI: => DI_OK
GDI: DiExecGetStatus(cpu_status = (cause = GDI_WAIT_MISCELLANEOUS, brkpt_id = 0))
GDI: DiRegisterRead(PC (id:0xB))
GDI: => DI_OK
GDI: PC (id:0xB) -> 0xFD0003
GDI: => DI_OK
GDI: DiRegisterRead(SP (id:0xA))
GDI: => DI_OK
GDI: SP (id:0xA) -> 0x0
GDI: DiMemoryRead(addr = 0x0, space = 1, mem_items = 3, size = 1)
GDI: => DI_OK
GDI: 05 1D 10
GDI: DiMemoryDownload(StartDownload)
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0000, space = 4, mem_items = 33, size = 4)
GDI: 00 1B 90 0D FF FE 00 10 0C 80 02 08 0C 26 06 DB CA 06 C9 A4 40 9E 40 58 00 BF 9E 04 C4 06 C9 CA
GDI: 06 C9 A4 40 9E 40 78 00 80 9E 04 C4 06 C9 BC 06 C6 BC 06 C4 1C 77 06 C5 1C 72 06 DE 0C 80 06 DA
GDI: BC 06 CA 0C 58 06 C4 02 80 06 C7 00 BC 06 DB CA 06 CC A4 40 9E 40 58 00 BF 78 00 20 9E 04 C4 06
GDI: CC BC 06 D0 1C 75 06 DD BA FD 06 B4 00 00 00 01 FD 00 80 FD 10 87 00 00 FD 00 87 00 00 FD 00 87
GDI: 00 10 00 00
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0084, space = 1, mem_items = 3, size = 1)
GDI: 00 00 70
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0087, space = 1, mem_items = 1, size = 1)
GDI: 1A
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0088, space = 4, mem_items = 78, size = 4)
GDI: F9 1D 71 06 0C A0 10 5B 0B 10 80 BB CA 06 10 A4 40 9E 40 02 30 1A 99 00 10 60 CA 06 25 A4 40 9E
GDI: 46 4E 77 00 00 00 02 08 9E C8 64 20 07 0E 00 10 60 64 1D E4 04 62 A8 64 08 42 C8 64 A0 62 C0 60
GDI: 98 00 10 50 A4 10 5A 9E 46 4E 77 00 00 00 02 08 8E A0 60 C0 40 CA 02 C0 A4 40 9E 40 58 00 FB 9E
GDI: 04 C4 02 C0 A4 10 5A 9E 40 30 9E 04 C4 10 5A A4 10 5A F4 74 26 10 1C 71 10 5D BC 10 5A BD 10 5B
GDI: BB FD 01 DF A0 10 5B 0B 10 80 3C BD 60 20 08 A0 71 60 60 C0 60 A0 74 F0 60 22 76 CA 02 C0 A4 40
GDI: 9E 40 88 74 9E 04 C4 02 C0 CA 06 02 A4 40 9E 40 02 18 79 0C 20 06 05 CA 06 05 A4 40 0B 04 7B 0C
GDI: 40 06 05 0A 67 1B 90 A4 06 08 9E 40 58 00 F8 0B 10 11 BD 10 5B A0 06 00 78 40 00 C0 06 00 20 0A
GDI: 1C 76 06 08 0C 40 06 09 BB FD 01 E8 1B 90 0C 80 06 09 BD 10 5B BB FD 01 E9 1B 90 0C 40 02 D7 BB
GDI: FD 01 C5 1B 90 A0 05 D0 50 61 A8 C0 05 D0 1C 71 05 CE BB FD 01 C0 1B 90 A0 05 D2 50 00 19 C0 05
GDI: D2 A0 10 6E 30 C0 10 6E A0 10 6E 0B 00 07 1C 71 10 6B 1C 72 05 CE 1B 90
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD01C0, space = 4, mem_items = 738, size = 4)
GDI: BB FD 02 31 05 1A FE BD 60 20 08 A0 71 60 60 C0 60 A0 7A F0 60 22 76 3C BB FD 06 C4 0A 62 05 98
GDI: 00 10 0C BB FD 07 0D 05 05 05 BB FD 07 3F BB FD 02 20 BB FD 02 8C 20 00 ED F0 09 91 ED E0 09 91
GDI: 05 1A FF C4 60 A4 71 F4 60 26 0C A4 02 C0 7C 80 C4 02 C0 20 0A A4 02 C0 5C 7F C4 02 C0 0A 61 05
GDI: BC 10 1B BD 10 19 BC 10 18 BD 10 16 BB FD 06 3D 05 1A FE A0 10 14 30 C0 10 14 A0 10 14 1B 38 45
GDI: 00 05 0B 00 1A 1C 10 1B 60 A4 71 64 60 C4 10 1B A4 60 0B 14 0A A0 10 19 30 C0 10 19 A0 10 14 1B
GDI: 38 45 00 64 0B 00 1A 1C 10 18 61 A4 71 64 61 C4 10 18 A4 61 0B 14 0A A0 10 16 30 C0 10 16 A0 10
GDI: 14 E0 03 E8 26 05 BD 10 14 0A 62 05 BB FD 02 BA A4 10 1B 0B 14 11 BB FD 06 42 A5 10 1B A4 71 85
GDI: BC C5 10 1B A4 10 18 0B 14 65 BB FD 06 81 A5 10 18 A4 71 85 BC C5 10 18 20 54 BB FD 06 85 05 1A
GDI: FD C4 60 C0 61 98 00 10 20 A4 60 9E 46 4E 77 00 00 00 02 A1 8E F1 61 24 16 98 00 10 20 A4 60 9E
GDI: 46 4E 77 00 00 00 02 08 8E A1 61 C1 40 98 00 10 00 A4 60 9E 46 4E 77 00 00 00 02 A1 8E F1 61 23
GDI: 16 98 00 10 00 A4 60 9E 46 4E 77 00 00 00 02 08 8E A1 61 C1 40 0A 63 05 1A F3 A4 10 48 0B 14 22
GDI: A0 10 0C 3C 21 FF 9B A0 10 0E A4 71 21 FF 93 A0 10 12 A4 72 21 FF 8B A0 10 14 A4 73 21 FF 83 1C
GDI: 10 1C 60 A4 71 64 60 C4 10 1C 1C 60 10 28 98 00 10 28 08 42 A0 10 0C 10 10 74 9E 04 C4 40 98 00
GDI: 10 28 08 43 A0 10 0C 58 00 FF 9E 04 C4 40 98 00 10 28 08 44 A0 10 20 10 10 74 9E 04 C4 40 98 00
GDI: 10 28 08 45 A0 10 20 58 00 FF 9E 04 C4 40 98 00 10 28 08 46 A0 10 00 10 10 74 9E 04 C4 40 98 00
GDI: 10 28 08 47 A0 10 00 58 00 FF 9E 04 C4 40 A4 78 04 08 98 00 10 28 3C 0D 07 10 BE BB FD 0A ED 0A
GDI: 61 F4 7B 27 6B 98 00 10 1C 08 41 C8 61 1C E4 01 64 A4 71 64 64 C4 E4 01 1C 64 10 30 98 00 10 30
GDI: 08 42 A0 10 0E 10 10 74 9E 04 C4 40 98 00 10 30 08 43 A0 10 0E 58 00 FF 9E 04 C4 40 98 00 10 30
GDI: 08 44 A0 10 22 10 10 74 9E 04 C4 40 98 00 10 30 08 45 A0 10 22 58 00 FF 9E 04 C4 40 98 00 10 30
GDI: 08 46 A0 10 02 10 10 74 9E 04 C4 40 98 00 10 30 08 47 A0 10 02 58 00 FF 9E 04 C4 40 A4 78 04 08
GDI: 98 00 10 30 3C 0D 07 11 BE BB FD 0A ED 0A 61 F4 7B 27 6B 98 00 10 1C 08 42 C8 65 1C E4 05 68 A4
GDI: 71 64 68 C4 E4 05 1C 68 10 38 98 00 10 38 08 42 A0 10 10 10 10 74 9E 04 C4 40 98 00 10 38 08 43
GDI: A0 10 10 58 00 FF 9E 04 C4 40 98 00 10 38 08 44 A0 10 24 10 10 74 9E 04 C4 40 98 00 10 38 08 45
GDI: A0 10 24 58 00 FF 9E 04 C4 40 98 00 10 38 08 46 A0 10 04 10 10 74 9E 04 C4 40 98 00 10 38 08 47
GDI: A0 10 04 58 00 FF 9E 04 C4 40 A4 78 04 08 98 00 10 38 3C 0D 07 12 BE BB FD 0A ED 0A 61 F4 7B 27
GDI: 6B 98 00 10 1C 08 43 C8 69 1C E4 09 6C A4 71 64 6C C4 E4 09 1C 6C 10 40 98 00 10 40 08 42 A0 10
GDI: 12 10 10 74 9E 04 C4 40 98 00 10 40 08 43 A0 10 12 58 00 FF 9E 04 C4 40 98 00 10 40 08 44 A0 10
GDI: 26 10 10 74 9E 04 C4 40 98 00 10 40 08 45 A0 10 26 58 00 FF 9E 04 C4 40 98 00 10 40 08 46 A0 10
GDI: 06 10 10 74 9E 04 C4 40 98 00 10 40 08 47 A0 10 06 58 00 FF 9E 04 C4 40 A4 78 04 08 98 00 10 40
GDI: 3C 0D 07 13 BE BB FD 0A ED 0A 61 F4 7B 27 6B 0A 6D 05 1A F1 BB FD 0A DC 0B 14 80 C2 08 60 04 42
GDI: 08 6B 04 42 08 6F 04 42 08 E0 13 04 42 08 E0 17 BB FD 0C 18 0A 6C 0B 04 80 A4 A4 02 F0 5C DF C4
GDI: 02 F0 0D 07 E1 BE F6 6B 26 80 8A 94 A0 F4 60 26 09 1C 71 10 48 20 80 7D 94 40 F4 60 26 80 76 A0
GDI: 10 20 96 00 10 02 00 9E 68 BB FD 0F 30 A0 10 22 96 00 10 02 04 9E 68 BB FD 0F 30 A0 10 24 96 00
GDI: 10 02 08 9E 68 BB FD 0F 30 A0 10 26 96 00 10 02 0C 9E 68 BB FD 0F 30 A0 10 00 96 00 10 02 10 9E
GDI: 68 BB FD 0F 30 A0 10 02 96 00 10 02 14 9E 68 BB FD 0F 30 A0 10 04 96 00 10 02 18 9E 68 BB FD 0F
GDI: 30 A0 10 06 96 00 10 02 1C 9E 68 BB FD 0F 30 BC 10 48 A4 02 F0 7C 20 C4 02 F0 0A 6F 05 BB FD 01
GDI: F8 05 98 00 10 4D BB FD 10 40 9E 40 0B 00 08 1C 71 B8 20 03 38 9E 04 C4 10 49 A4 71 BB FD 02 01
GDI: 21 FC B8 3C BB FD 02 01 98 00 10 4B BB FD 10 40 9E 40 0B 00 08 1C 71 B8 20 03 38 9E 04 C4 10 4A
GDI: 05 21 FE F1 05 05 B6 FD 00 6C 27 14 B8 FD 00 70 A9 40 A7 43 BC F7 0B 87 7E 18 07 0B 86 75 05 B9
GDI: FD 00 73 27 10 A6 F7 27 0C A8 F7 1C F7 E7 0B 86 7D 20 74 05 1B 03 00 12 6F 21 FF CD 21 FF E3 BB
GDI: FD 01 EA 05 1A FF C4 60 A0 10 5B 0B 10 08 A4 78 20 80 3A A4 02 C0 8C 74 C4 02 C0 1D 72 10 5B BC
GDI: 10 5D BC 10 5A BD 10 58 A4 06 02 9E 40 02 18 7B 0C 20 06 05 A4 06 05 0B 04 7D 0C 40 06 05 A4 60
GDI: 0B 14 09 A0 10 5B 0B 00 7D 3C 0A 61 05 1A FD C8 60 A4 10 5D 0B 14 26 1D 10 50 E4 00 A8 60 08 42
GDI: A0 10 52 C0 40 A8 60 08 44 A0 10 54 C0 40 A8 60 08 46 A0 10 56 C0 40 3C 20 04 A4 79 0A 63 05 0C
GDI: 48 00 17 1C 75 00 19 0C 60 00 17 1C 75 00 19 1C 74 00 1A 1C 74 00 1B 0C 70 00 17 1C 74 00 1A 1C
GDI: 75 00 1B CA 02 00 A4 40 9E 40 58 00 FC 9E 04 C4 02 00 1C 78 05 C6 CA 05 EC A4 40 9E 40 88 73 9E
GDI: 04 C4 05 EC CA 05 E0 A4 40 9E 40 58 00 F3 9E 04 C4 05 E0 CA 05 C2 A4 40 9E 40 58 00 FC 9E 04 C4
GDI: 05 C2 CA 05 C0 A4 40 9E 40 88 73 9E 04 C4 05 C0 CA 05 C9 A4 40 9E 40 58 00 F0 9E 04 C4 05 C9 CA
GDI: 05 C7 A4 40 9E 40 58 00 FC 9E 04 C4 05 C7 CA 05 CD A4 40 9E 40 58 00 F7 9E 04 C4 05 CD 0C FF 05
GDI: CE CA 05 CC A4 40 9E 40 88 73 9E 04 C4 05 CC BC 05 EE BC 04 80 CA 04 85 A4 40 9E 40 58 00 EF 9E
GDI: 04 C4 04 85 CA 04 84 A4 40 9E 40 58 00 FD 9E 04 C4 04 84 CA 04 81 A4 40 9E 40 58 00 FD 9E 04 C4
GDI: 04 81 CA 02 F0 A4 40 9E 40 58 00 FE 78 00 60 9E 04 C4 02 F0 CA 02 98 A4 40 9E 40 88 7C 9E 04 C4
GDI: 02 98 CA 02 8C A4 40 9E 40 58 00 F3 9E 04 C4 02 8C CA 02 88 A4 40 9E 40 88 7C 9E 04 C4 02 88 CA
GDI: 02 86 A4 40 9E 40 88 7C 9E 04 C4 02 86 CA 02 84 A4 40 9E 40 58 00 F3 9E 04 C4 02 84 CA 02 F6 A4
GDI: 40 9E 40 58 00 9F 9E 04 C4 02 F6 CA 02 F3 A4 40 9E 40 58 00 9F 9E 04 C4 02 F3 CA 02 F2 A4 40 9E
GDI: 40 78 00 60 9E 04 C4 02 F2 CA 02 C0 A4 40 9E 40 58 00 7B 9E 04 C4 02 C0 CA 02 C3 A4 40 9E 40 58
GDI: 00 7B 9E 04 C4 02 C3 CA 02 C2 A4 40 9E 40 78 00 84 9E 04 C4 02 C2 CA 02 D4 A4 40 9E 40 58 00 BF
GDI: 9E 04 C4 02 D4 CA 02 D3 A4 40 9E 40 78 00 40 9E 04 C4 02 D3 CA 02 D2 A4 40 9E 40 58 00 BF 9E 04
GDI: C4 02 D2 CA 06 C8 A4 40 9E 40 58 00 ED 9E 04 C4 06 C8 CA 06 D1 A4 40 9E 40 58 00 FD 9E 04 C4 06
GDI: D1 CA 03 C1 A4 40 9E 40 58 00 FE 9E 04 C4 03 C1 CA 03 CF A4 40 9E 40 58 00 7F 9E 04 C4 03 CF CA
GDI: 02 FD A4 40 9E 40 58 00 8A 9E 04 C4 02 FD CA 02 09 A4 40 9E 40 58 00 BF 9E 04 C4 02 09 BB FD 0A
GDI: 9C BB FD 0D 49 BB FD 0C EB 0D 61 A8 05 D0 BB FD 0F DD BB FD 0F D8 0C 40 02 D7 ED E0 02 D6 BB FD
GDI: 10 7B 0C 88 05 C6 CE EF 05 1A DB C6 60 C8 64 BF E0 17 08 E0 17 08 44 0D FF FF BF 6F 60 0D FF FF
GDI: BE 6E E0 28 4E 3E C6 40 0D FF FF BF 6F 60 16 33 E0 28 78 5E 00 00 FF FF 4E 3E C6 E0 13 A0 E0 15
GDI: 9E 06 C6 6F 08 E0 17 08 42 C8 E0 1F A6 E4 1F 66 6F C6 E4 1F A0 E0 13 9E 06 66 E0 17 C6 E0 17 17
GDI: 33 60 78 5F 00 00 FF FF 0D FF FF BE 6E E0 28 4E 3E C6 6B A0 6D 9E 06 C6 67 08 E0 17 08 42 C8 E0
GDI: 22 A6 E4 22 66 67 C6 E4 22 A0 6B 9E 06 66 E0 17 C6 E0 17 17 33 60 78 5F 00 00 FF FF 16 33 E0 28
GDI: 78 5E 00 00 FF FF 4E 3E 66 E0 17 C6 E0 17 1F E0 17 E4 04 A8 64 08 44 A6 E0 1B C6 40 1A 25 05 1A
GDI: F9 C6 60 C8 64 16 33 60 74 0B 06 80 3F A6 6A 02 BE 27 17 33 6A 7C 16 73 60 74 8F BE E7 00 00 FF
GDI: FF 24 27 17 33 6A 7C 16 73 60 74 8F BE 9E 70 30 C0 E4 04 3C 20 25 17 33 6A 7C 16 73 60 74 8F BE
GDI: 9E 70 C0 E4 04 3C 20 13 17 33 6A 7C 16 73 60 74 8F BE 9E 70 C0 E4 04 A4 71 0A 67 05 BC 10 5D BD
GDI: 10 5B BD 06 00 98 00 10 08 C8 06 1D 98 00 10 60 C8 06 21 0C 84 06 04 1C 76 06 03 BC 06 25 1C 76
GDI: 06 08 0C FC 06 06 0C C0 06 09 0C C0 06 07 1D 71 06 0C 1D 71 06 0A 0D 88 40 06 00 05 A4 08 04 9E
GDI: 40 02 00 08 1C 71 B8 20 03 38 9E 04 05 1A E4 C6 60 C4 64 C8 65 A6 60 03 FE 10 0D 07 FF BE F6 60
GDI: 24 07 A4 73 20 81 11 A6 60 02 FE 12 96 60 00 00 00 6E 60 0B 16 08 A4 73 20 80 FD A4 78 F4 E0 1F
GDI: 24 07 A4 73 20 80 F1 A4 71 F4 64 24 07 A4 73 20 80 E6 A4 08 06 9E 40 68 77 0B 00 08 A4 7B 20 80
GDI: D7 A4 08 06 C4 08 0A 0E 00 08 30 6D A6 60 02 FE 21 96 1F FC 00 00 6E 60 16 5E 71 7E 00 18 00 00
GDI: 97 00 03 FF FF 6F 60 17 47 8E BF C6 69 20 08 16 7B 60 7A C6 69 A8 6D 08 43 A4 6C C4 40 A8 6D 08
GDI: 42 A4 6B C4 40 A8 6D 08 41 A4 6A C4 40 1C 69 E4 0D A4 64 0B 04 80 51 BC 68 20 1C A8 6D 08 44 A4
GDI: 68 9E 46 09 8E A8 65 A4 68 9E 46 A4 8E C4 50 A4 71 64 68 C4 68 A4 E0 1F F4 68 22 61 A6 60 02 FE
GDI: 15 A8 6D 08 43 C8 E0 10 94 FE 6C E4 10 C4 E4 10 20 80 39 A8 6D 08 41 C8 E0 13 94 EF 6C E4 13 C4
GDI: E4 13 20 27 A6 60 02 FE 14 A8 6D 08 43 C8 E0 16 A4 71 8C E4 16 C4 E4 16 20 11 A8 6D 08 41 C8 E0
GDI: 19 94 10 8C E4 19 C4 E4 19 1C E0 1F 08 3C A4 08 0A C4 08 06 3C 1A 1C 05 1A F8 C8 60 BF 64 03 80
GDI: 08 04 0A A4 7A 20 80 C3 1C 08 20 64 08 64 08 41 A4 08 21 C4 40 08 64 08 42 A4 08 22 C4 40 08 64
GDI: 08 43 A4 08 23 C4 40 A6 64 02 9E 20 17 23 64 5F 00 03 FF FF 16 3B 64 71 5E 1F FC 00 00 8F BE 7F
GDI: 80 00 00 00 C7 E4 00 20 09 16 3B 64 7A C6 E4 00 A6 E4 00 02 FE 27 1C 71 E4 0E A4 08 23 9E 40 02
GDI: 00 08 1C 71 B8 20 03 38 9E 04 C4 E4 0B 96 7F FF FF FF 6E E4 00 C6 E4 00 20 18 BC E4 0E A4 08 21
GDI: 9E 40 02 20 08 1C 71 B8 20 03 38 9E 04 C4 E4 0B A4 08 2C 6C 7F C4 E4 11 A4 E4 0B 0B 04 28 BC 63
GDI: 20 1C A8 E0 14 A4 63 9E 46 09 8E CA 08 24 A4 63 9E 46 A4 8E C4 50 A4 71 64 63 C4 63 A4 E4 11 F4
GDI: 63 22 61 1C 71 08 04 3C 0A 68 05 0C 80 08 01 1C 71 08 00 A4 08 0B 5C CF C4 08 0B BC 08 10 BC 08
GDI: 11 BC 08 12 BC 08 13 BC 08 18 BC 08 19 BC 08 1A BC 08 1B 0C FF 08 14 0C FF 08 15 0C FF 08 16 0C
GDI: FF 08 17 0C FF 08 1C 0C FF 08 1D 0C FF 08 1E 0C FF 08 1F 0C 80 08 02 0C 49 08 03 EC E0 08 01 EC
GDI: 80 08 00 03 80 08 01 00
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0D48, space = 1, mem_items = 1, size = 1)
GDI: 05
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0D49, space = 1, mem_items = 3, size = 1)
GDI: A4 09 97
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0D4C, space = 4, mem_items = 8, size = 4)
GDI: 7C FB C4 09 97 A4 09 90 8C 72 C4 09 90 A4 09 96 5C E6 C4 09 96 A4 09 91 5C CE 7C C6 C4 09 91 05
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0D6C, space = 4, mem_items = 156, size = 4)
GDI: 1A F7 C8 60 C0 63 C1 65 1D 63 67 20 32 98 00 10 65 A0 67 1B 30 45 00 02 9E 06 4E 77 00 00 00 02
GDI: 09 8E A8 60 A0 67 1B 30 45 00 02 9E 06 4E 77 00 00 00 02 A0 8E C0 50 A0 72 60 67 C0 67 A0 65 F0
GDI: 67 22 4C 0A 69 05 1A F1 C8 60 C0 63 C1 65 BC 6E A0 65 F0 63 26 06 3C 20 80 B4 1D 63 6C A8 60 9E
GDI: 86 C6 68 20 15 1B 0C 60 40 03 86 0B 14 06 1C 71 6E 1C 78 BE 66 68 C6 68 A0 65 F0 6C 23 80 85 0C
GDI: 30 03 86 1C 75 03 82 0C 11 03 8C CA 03 8C 08 41 16 33 68 78 9E 64 C4 40 A6 68 9E 60 C0 03 8E BC
GDI: 67 20 08 A4 71 64 67 C4 67 A4 74 F4 67 23 80 3B CA 03 90 A4 67 9E 46 4E 77 00 00 00 02 09 8E A8
GDI: E0 12 A0 6C 1B 30 45 00 02 9E 06 4E 77 00 00 00 02 A0 8E C0 50 A0 72 60 6C C0 6C A0 65 F0 6C 22
GDI: 44 A4 67 64 72 C4 03 82 0C 80 03 86 02 F0 03 86 00 A4 03 86 9E 40 58 00 30 0B 10 FF 6C A4 79 20
GDI: 0C A4 6E 0B 14 07 A4 73 20 03 3C 0A 6F 05 1A FD C8 60 03 F0 03 86 0A A4 78 20 80 46 0C 30 03 86
GDI: 1C 71 03 82 0C 12 03 8C CA 03 8C 09 41 A8 60 9E 86 16 16 78 9E 64 C4 50 A8 60 9E 86 5E FF FF FF
GDI: FE 9E 60 C0 03 8E 0C 80 03 86 02 F0 03 86 00 A4 03 86 9E 40 58 00 23 0B 10 07 A4 79 20 03 3C 0A
GDI: 63 05 1A FB C8 60 C0 63 03 F0 03 86 0A A4 78 20 80 52 0C 30 03 86 1C 72 03 82 0C 11 03 8C CA 03
GDI: 8C 09 41 A8 60 9E 86 16 16 78 9E 64 C4 50 A8 60 9E 86 9E 60 C0 03 8E 1D 63 03 90 0C 80 03 86 A4
GDI: 03 86 9E 40 58 00 30 0B 10 07 A4 79 20 15 02 F0 03 86 00 1B 0C 60 40 03 86 0B 14 07 A4 73 20 03
GDI: 3C 0A 65 05 1A F7 C8 60 C0 63 A8 60 9E 86 E6 00 10 00 00 25 80 94 A8 60 9E 86 E6 00 10 07 FF 22
GDI: 80 88 A8 60 9E 86 02 06 08 A4 79 20 80 7E 02 F0 03 86 80 75 A0 E4 00 E0 FF FF 26 0C A0 63 A8 60
GDI: 21 FF 62 20 80 66 A8 60 9E 86 5E 00 FF FF FC 9E 68 C8 66 A1 74 38 A8 66 21 FD E8 99 00 10 65 A8
GDI: 60 9E 86 1B 3E 77 00 00 00 04 1B 36 77 00 00 00 02 4E 77 00 00 00 02 08 9E A0 63 C0 40 A8 60 21
GDI: FE CF C4 65 A4 65 0B 14 07 A4 65 20 1E 98 00 10 65 04 42 A1 74 38 A8 69 21 FD EE 0A 63 C4 65 A4
GDI: 65 20 08 A4 78 20 04 A4 72 0A 69 05 0C 18 03 80
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0FDC, space = 1, mem_items = 1, size = 1)
GDI: 05
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0FDD, space = 1, mem_items = 3, size = 1)
GDI: CA 04 8C
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD0FE0, space = 4, mem_items = 11, size = 4)
GDI: 08 41 BC 40 BD 10 69 CA 04 9C 08 41 BC 40 CA 04 94 08 41 0C FF 40 1C 71 04 83 0C A3 04 88 A4 04
GDI: 82 8C 72 C4 04 82 A4 04 80 8C 72 C4
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD100C, space = 1, mem_items = 3, size = 1)
GDI: 04 80 05
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD100F, space = 1, mem_items = 1, size = 1)
GDI: 04
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFD1010, space = 4, mem_items = 35, size = 4)
GDI: 10 DE 10 1C 60 FA 00 10 64 1A 01 A0 10 6E C0 10 6C A4 10 6B 0B 14 10 1A FF 1C FA 00 10 64 60 04
GDI: 90 A4 71 05 1A FF 1C FA 00 10 64 60 04 90 3C 05 1A F5 C8 60 21 FF CB 0B 14 07 A4 74 20 2C 96 01
GDI: 00 00 00 04 48 08 67 A0 10 6C 9E 06 BB FD 09 89 0A 64 A6 67 04 48 A8 64 A6 67 BB FD 0A 3F 0A 64
GDI: 0B 14 07 A4 75 20 03 3C 0A 6B 05 BD 10 6E BC 10 6B 0D 00 19 05 D2 05 00 00 00 0A 00 10 00 FF FF
GDI: FF FF FF FF FF FF C0 D2 00 00 00 00
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0xFFFE10, space = 4, mem_items = 124, size = 4)
GDI: FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00
GDI: FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 01 83 FF FD 00 00 FF FD 00 00
GDI: FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 87 FF FD 01 76 FF FD 01 4F
GDI: FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 01 A0 FF FD 01 8D
GDI: FF FD 00 00 FF FD 00 00 FF FD 00 00 FF FD 00 03
GDI: => DI_OK
GDI: DiMemoryDownload(EndDownload)
Starting 3rd party flash programming...
INF: Copyright 2017 P&E Microcomputer Systems,Inc.
INF: Command Line :"C:\Freescale\CW MCU v11.0\eclipse\..\MCU\bin\de.exe" -noni -language en -ORBendPoint giop:tcp:127.0.0.1: -ORBtraceLevel 0
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : PEDEBUG, Entry : IS_GDB_CONFIG, Value : 0, R) => DI_ERR_NONFATAL
INF: CMD>RE
INF: Initializing.
INF: Target has been RESET and is active.
INF: CMD>CM C:\Freescale\CW MCU v11.0\MCU\bin\Plugins\support\s12z\gdi\P&E\freescale_9s12zvca192_1x16x96k_all.s12zp
INF: Initializing.
INF: (Bus Freq = 12528KHz)
INF: Initialized.
INF: ;version 1.03, 6/27/2014, Copyright P&E Microcomputer Systems, www.pemicro.com [freescale_9s12zvc192_pflash]
INF: ;device freescale, 9s12zvca192, 1x16x96k, desc=all
INF: ;begin_cs device=$00100000, length=$00030000, ram=$00001000
INF: Loading programming algorithm ...
INF: Done.
INF: CMD>VC
INF: Verifying object file CRC-16 to device ranges ...
INF: block 00FD0000-00FD109B ...
INF: Ok.
INF: block 00FFFE10-00FFFFFF ...
INF: Ok.
INF: Checksum Verification Successful. (Cumulative CRC-16=$C2AD)
INF: Application verified in memory. No need to reprogram.
INF: CMD>RE
INF: Initializing.
GDI: => DI_OK
GDI: DiRegisterWrite(PC (id:0xB), value = 0xFD0003)
GDI: => DI_OK
GDI: DiMemoryRead(addr = 0xFD01EA, space = 1, mem_items = 1, size = 1)
GDI: => DI_OK
GDI: BB
GDI: DiMemoryRead(addr = 0x100, space = 0, mem_items = 1, size = 1)
GDI: => DI_OK
GDI: 00
GDI: DiMemoryRead(addr = 0x120, space = 0, mem_items = 1, size = 1)
GDI: => DI_OK
GDI: 00
GDI: => DI_OK
GDI: 00
GDI: DiMemoryWrite(addr = 0x100, space = 0, mem_items = 1, size = 1)
GDI: 00
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0x120, space = 0, mem_items = 1, size = 1)
GDI: 21
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0x125, space = 0, mem_items = 3, size = 1)
GDI: FD 01 EA
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0x107, space = 0, mem_items = 1, size = 1)
GDI: FF
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0x108, space = 0, mem_items = 1, size = 1)
GDI: FF
GDI: => DI_OK
GDI: DiMemoryWrite(addr = 0x109, space = 0, mem_items = 1, size = 1)
GDI: FF
GDI: => DI_OK
GDI: => DI_OK
GDI: 00
GDI: 98
GDI: => DI_OK
GDI: => DI_OK
GDI: 98
GDI: 98
GDI: => DI_OK
GDI: DiExecContinue()
GDI: => DI_OK
INF: Flash Programming Successful.
GDI: DiExecGetStatus(cpu_status = (cause = GDI_WAIT_RUNNING, brkpt_id = 0))
GDI: DiExecStop()
GDI: => DI_ERR_NONFATAL
GDI: Non Fatal Error
GDI: DiExecStop()
GDI: => DI_OK
GDI: 00
GDI: 00
GDI: => DI_OK
GDI: 00
GDI: => DI_OK
GDI: DiMeeDisconnect(exec_env_id = 1)
GDI: => DI_OK
GDI: DiGdiClose()
GDI: => DI_OK
标记 (3)
6,461 次查看
jinliangsun
I fixed this problem by deselecting the bus clock as debugger controller clock source.
9 回复数
6,461 次查看
ZhangJennie
Thanks for the sharing.
Jennie Zhang
6,462 次查看
jinliangsun
6,461 次查看
ZhangJennie
From your setting you use 8M external clock. Can you please check if  this external clock function well?
6,461 次查看
jinliangsun
Yes I can download my program image to the board and the board works well with my program.
The only issue is that I can't debug step by step to check my program. Now to debug my program I have to add several CAN messages to monitor some variables.
Thanks.
Bruce
6,461 次查看
ZhangJennie
I couldn't reproduce. Can you please create a demo project to showcase your problem?
6,459 次查看
jinliangsun
Please check the zipped file.
6,459 次查看
jinliangsun
I changed the debug program execution to Program Entry Point and found the trouble is made by setting Post Divider Register (CPMUPOSTDIV) register.
Is anything wrong with my settings?
6,459 次查看
jinliangsun
Hi Jennie,
1 So can you please clarify when the code can be debugged and when not?
-> I can't debug this specific project, but I can debug other projects such as a new created empty project.
2 Besides, If we create a NEW project with wizard in a NEW workspace, can you correct the board and debug step over?
-> If you mean a NEW(empty) project, yes. For the project I'm working on, I used many PE components and I don't want to create a new project re-configuring all these components again.
6,459 次查看
ZhangJennie
Hi Jinliang
Sorry, maybe I don't understand.
As in the beginning of your question you mentioned you couldn't debug because of the connection error.
Later you mentioned "Actually if I try to debug the sample project, it works fine."
Jennie Zhanng
