Could anybody support a temporary license which has no code limitation of 32Kbyte for CW5.1 at least one weekly? My customer asks for it urgently, Please help!
1,280 次查看
jacobtang
as the topic, Thanks a lot!
1,134 次查看
ZhangJennie
Hi Jocab
First time evaluators can download CW for HCS12 from this link:
CodeWarrior® Dev Tools for HCS12(X) MCUs|NXP
after install you can see evaluation license under CW install folder. the CW is v5.2 but the evaluation license included is for all CW 5.x versions.
If customer already did this , they must have an entitlement which they can check and ask to be extended thru create a private case. We can't provide an evaluation license from this community.
 How to submit a new question for NXP Support
How to get the entitlement ID ?  Ask customer to check their Order History within the Software Licensing portal , and look for the EVALUATION Catalog they need to extend.
Jennie Zhang
1,135 次查看
ZhangJennie
Hi Jocab
Jennie Zhang
