Codewarrior failed to upload firmware!
3,262 次查看
rla00220
i use wct1013a.
I uploaded the bootloader and firmware using code warrior.
The bootloader works normally, but the firmware doesn't work normally.
What is mean 'No data to be programmed in selected flash memory range. '?
I set it up like this. Is there a problem?
Attached below is the log.
fl::target -lc "LC for Simple Flash"
fl::target -b 0x60400 0x1000
fl::target -v off -l off
cmdwin::fl::device -d "MWCT1013A_P_FLASH" -o "144kx16x1" -a 0x0 0x6bfff
cmdwin::fl::image -f "C:\\workspace\\SW V4.0 and Tech Docs\\WCT-15WTXAUTO_V4.0\\WCT-15WTXAUTO_V4.0\\15W_MP\\build\\demo\\wct1013Ademo\\demo_ldm_release\\wct1013Ademo_release.elf.S" -t "Auto Detect" -re on -r 0x0 0x6bfff -oe off
cmdwin::fl::erase image
Operation canceled.
cmdwin::fl::erase all
Beginning Operation ...
Performing target initialization ...
Error: Connect Failed.
Unknown Fault. The Debugger can not connect to the P&E device(GDI Procotol fatal error:)
Erasing ..........
Erase Command Succeeded.
cmdwin::fl::device -d "MWCT1013A_X_FLASH" -o "152kx16x1" -a 0x8000 0x3ffff
Erasing ..........
cmdwin::fl::blankcheck all
Flash Operation.
Blank Checking ..........
BlankCheck Command Succeeded.
Flash Operation.
Auto-detection is successful.
File is of type Motorola S-Record Format.
Erasing ..............
cmdwin::fl::write
Flash Operation. ...
Programming ...
Program Command Succeeded
Flash Operation. done
cmdwin::fl::image -f "C:\\workspace\\SW V4.0 and Tech Docs\\WCT-15WTXAUTO_V4.0\\WCT-15WTXAUTO_V4.0\\15W_MP\\build\\demo\\wct1013Ademo\\demo_ldm_release\\wct1013Ademo_release.elf.S" -t "Auto Detect" -re on -r 0x8000 0x3ffff -oe off
Nothing to erase. No sectors selected
cmdwin::fl::write
Programming ...
Programming warning. No data to be programmed in selected flash memory range.
3,114 次查看
rla00220
hi.
Thank you for your help. I solved the connection problem.
But the problem is the same. I'll reattach the log.
cmdwin::fl::image -f "C:\\workspace\\test\\15W_MP\\build\\demo\\wct1013Ademo\\demo_ldm_release\\wct1013Ademo_release.elf.S" -t "Auto Detect" -re on -r 0x0 0x6bfff -oe off
cmdwin::fl::write
Programming ...
cmdwin::fl::image -f "C:\\workspace\\test\\15W_MP\\build\\demo\\wct1013Ademo\\demo_ldm_release\\wct1013Ademo_release.elf.S" -t "Auto Detect" -re on -r 0x8000 0x3ffff -oe off
cmdwin::fl::write
Programming ...
3,114 次查看
xiangjun_rong
Hi, Kim,
I suspect that the S-Recorder file format is incorrect.
I attach the screenshot, which tell you how to configure the S-Recorder file.
XiangJun Rong
3,114 次查看
xiangjun_rong
Hi, Kim,
I have tried to download code to flash based on MC56F84789 based on usbtap device, no problem. I copy my log.
Regarding your issue, from the log, it appears that the multilink universal device has issue from the error message "Unknown Fault. The Debugger can not connect to the P&E device(GDI Procotol fatal error:)".
can you use usbtap device and have a try?
secondly, can you download the *.elf  file to flash with the CW for mcu ver11.c tools itself by clicking Run->Debug Configuration....?
Can you see the Multilink Universal device icon in Device Manager on PC?
Hope it can help you
XiangJun Rong
cmdwin::fl::device -d "MC56F84789_P_FLASH" -o "144kx16x1" -a 0x0 0x6bfff
cmdwin::fl::image -f "C:\\DriveE\\CWCode\\DSC\\LED_8400Board\\FLASH_SDM\\LED_8400Board.elf.S" -t "Auto Detect" -re on -r 0x0 0x6bfff -oe off
 Erasing ..........
cmdwin::fl::write
 Programming ...
cmdwin::fl::device -d "MC56F84789_X_FLASH" -o "152kx16x1" -a 0x8000 0x3ffff
cmdwin::fl::image -f "C:\\DriveE\\CWCode\\DSC\\LED_8400Board\\FLASH_SDM\\LED_8400Board.elf.S" -t "Auto Detect" -re on -r 0x8000 0x3ffff -oe off
Image size is 0 bytes, nothing to erase.
cmdwin::fl::write
 Programming ...
