CodeWarrior downloading S32DS' elf file
855 次查看
kmliu
Dear sir,
We found that the elf file generating from S32DS can't work downloading by codewarrior using PnE multilink recently.
Is there compatible between elf of S32DS and codewarrior's ?
Thanks!
标记 (3)
744 次查看
stanish
elf file generated with S32DS (default settings) is dwarf-4 which is not supported by CodeWarrior.
I'd recommend you to switch S32DS to generate dwarf-2: https://community.nxp.com/message/870465?commentID=870465#comment-870465
Hope it helps
Stan
