CodeWarrior U-Boot Debugging
This document describes the steps required for U-Boot debugging using the CodeWarrior IDE for low-end and high-end Power Architecture CPU, from NOR, NAND, SPI and SD card flash devices.
标记 (2)
附件
评论
Good application note.
Hello Adrian,
Do we have guide of CodeWarrior U-Boot debugging for e5500 and e6500? Thanks!
Lunmin
The chapter that address e500mc should works also for e5500 and e6500. The scenario is the same for high end CPUs.
Adrian
Thank you Adrian.
无评分
版本历史
最后更新:
‎04-16-2014 05:32 AM
更新人:
