Code size limitation error-Codewarrior IDE
astha
We have Code warrior IDE ver 5.1 installed on our machine and observed "Code size limitation error 1856>512 bytes" error while compiling the code.
We then upgraded SW to CW ver 5.2 and still observed the error.
OS: Windows 10
Please let me know if you have any suggestion.
Thanks.
Astha Ganjoo
Tags (2)
ErichStyger
Specialist I
Without a license, it runs in code size limited mode. Have you installed your license file?
Or have you installed the special edition?
astha
Hi Erich
Thanks for your reply.
I have Special Edition.
Also,do you know if CW 5.1 is compatible with Win 10?How about CW 5.2 and Win 10 compatibility?
ErichStyger
Specialist I
I have CW 5.2 running on Win 10 64bit and that works fine. There are only occacional IDE crashes on IDE exit.
astha
Thank you.
Do you suggest to install the Professional/Standard license instead of special edition to get rid of code size limitation error?
ErichStyger
Specialist I
No, unless you have purchased a Pro/Standard license (then why would you use the special edition?).
You need to check the About /license box of your HI-WAVE debugger to see what his wrong with your licensing. Maybe the license file is not found?
astha
Thank you.
