Client open CW2.10 IDE error
leolv
Our company  have purchased CW Perpetual-Floating version and received the U disk. then i setup the environment following the spec "FLOATING LICENSE
INSTALLATION FOR WINDOWS".
when i try to open CW2.10 from client, it report error "no valid license key was found", more information please refer to attachment. Who can help to setup this?
leolv
Client can use the server license file now, but if the network is not ok, client will stop working immediately. Is that normal?
ZhangJennie
yes,it's normal. if using floating license we must make sure local network well.
Have a nice day,
Jun Zhang
leolv
If a computer that is not on the same local area network as the server wants to access and use the CW floating license on our server, how can it be done
ZhangJennie
HI leolv ,.
The error message means your CW doesn't find correct license on server.
First ping server from client, make sure network  ok.
then change license file
TO: Your license server's host IP address, or your license server's host name
make sure the license.dat file is installed under both server FlexIM folder and client CW install folder.
Restart computer after everything set up.
If still has problem, create a private case to NXP license support team, with you license file. As it is related with personal asset, we can't post ti to public comunity.
Have a nice day,
Jennie
%3CLINGO-SUB%20id%3D%22lingo-sub-1810715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EClient%20open%20CW2.10%20IDE%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1810715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOur%20company%26nbsp%3B%20have%20purchased%20CW%20Perpetual-Floating%20version%20and%20received%20the%20U%20disk.%20then%20i%20setup%20the%20environment%20following%20the%20spec%20%22FLOATING%20LICENSE%3CBR%20%2F%3EINSTALLATION%20FOR%20WINDOWS%22.%3C%2FP%3E%3CP%3Ewhen%20i%20try%20to%20open%20CW2.10%20from%20client%2C%20it%20report%20error%20%22no%20valid%20license%20key%20was%20found%22%2C%20more%20information%20please%20refer%20to%20attachment.%20Who%20can%20help%20to%20setup%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Client%20open%20CW2.10%20IDE%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20a%20computer%20that%20is%20not%20on%20the%20same%20local%20area%20network%20as%20the%20server%20wants%20to%20access%20and%20use%20the%20CW%20floating%20license%20on%20our%20server%2C%20how%20can%20it%20be%20done%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Client%20open%20CW2.10%20IDE%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eyes%2Cit's%20normal.%3CSPAN%3E%26nbsp%3Bif%20using%20floating%20license%20we%20must%20make%20sure%20local%20network%20well.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHave%20a%20nice%20day%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJun%20Zhang%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Client%20open%20CW2.10%20IDE%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EClient%20can%20use%20the%20server%20license%20file%20now%2C%20but%20if%20the%20network%20is%20not%20ok%2C%20client%20will%20stop%20working%20immediately.%20Is%20that%20normal%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1811754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Client%20open%20CW2.10%20IDE%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1811754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3Bleolv%26nbsp%3B%2C.%3C%2FP%3E%0A%3CP%3EThe%20error%20message%20means%20your%20CW%20doesn't%20find%20correct%20license%20on%20server.%3C%2FP%3E%0A%3CP%3EFirst%20ping%20server%20from%20client%2C%20make%20sure%20network%26nbsp%3B%20ok.%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ethen%20change%20license%20file%3C%2FP%3E%0A%3CP%3EFROM%3A%20this_host%3CBR%20%2F%3ETO%3A%20Your%20license%20server's%20host%20IP%20address%2C%20or%20your%20license%20server's%20host%20name%3C%2FP%3E%0A%3CP%3Emake%20sure%20the%20license.dat%20file%20is%20installed%20under%20both%20server%20FlexIM%20folder%20and%20client%20CW%20install%20folder.%3C%2FP%3E%0A%3CP%3ERestart%20computer%20after%20everything%20set%20up.%3C%2FP%3E%0A%3CP%3EIf%20still%20has%20problem%2C%20create%20a%20private%20case%20to%20NXP%20license%20support%20team%2C%20with%20you%20license%20file.%20As%20it%20is%20related%20with%20personal%20asset%2C%20we%20can't%20post%20ti%20to%20public%20comunity.%3C%2FP%3E%0A%3CP%3EHave%20a%20nice%20day%2C%3C%2FP%3E%0A%3CP%3EJennie%3C%2FP%3E%3C%2FLINGO-BODY%3E
