CW10.5.1 CCSProtocolPlugin : Failed to reset the target
6,195 次查看
harryz
Dear Sir,
Please help me!
On A 2040 Bare board,  I want to program uboot into the nor flash. but always shows
“Failed to reset the target”
The details are below:
  1. Start CW 10.5.1  (build ID:160128)
 PPC 2040
2.Push debug button:
I want to program the uboot into the nor falsh
Always shows: “ failed to reset the target “  Please tell me why?
Log below:
ccs_open
ipaddr = 127.0.0.1
port = 41475
timeout = 15
serverh = 0
ccs_open; ccs_error = 10
Error message: Connection refused
ccs_open
ipaddr = 127.0.0.1
port = 41475
timeout = 15
serverh = 0
ccs_open; ccs_error = 0
ccs_get_connection_count
serverh = 0
count = 1
ccs_get_connection_count; ccs_error = 0
ccs_available_connections
serverh = 0
count = 0
ccs_available_connections; ccs_error = 0
serverh = 0
count = 0
ccs_config_cc
serverh = 0
config_string = cwtap:0
ccs_config_cc; ccs_error = 0
serverh = 0
count = 1
ccs_cc_version
serverh = 0
cc = 0
version.major = 0
version.minor = 0
ccs_cc_version; ccs_error = 0
ccs_set_timeout
serverh = 0
timeout = 15
ccs_set_timeout; ccs_error = 0
serverh = 0
count = 1
ccs_config_server
serverh = 0
cc = 0
server_config = 0
value = 1000
ccs_config_server; ccs_error = 0
ccs_get_config_chain
serverh = 0
device_list: (size = 0)
ccs_get_config_chain; ccs_error = 0
ccs_config_chain
serverh = 0
cc = 0
device_list: (size = 1)
device[0]:: core_type=p2040(173)
ccs_config_chain; ccs_error = 0
serverh = 0
device_list: (size = 5)
serverh = 0
device[1]:: core_type=e500mc core(119)
device[2]:: core_type=e500mc core(119)
device[3]:: core_type=e500mc core(119)
device[4]:: core_type=e500mc core(119)
ccs_send_message
coreh = [serverh:0;cc_index:0;chain_pos:1]
message = 3
ccs_send_message; ccs_error = 0
ccs_read_register
index = 30000
count = 1
size = 8
value: (size =
 00000000 FE000000
ccs_read_register; ccs_error = 0; duration=7 ms
ccs_read_memory
coreh = [serverh:0;cc_index:0;chain_pos:0]
addr = [space:0x92;size:4;address_hi:0x00000000;address_lo:0xfe0e2094]
data: (size = 4)
 00000000
ccs_read_memory; ccs_error = 0; duration=4 ms
ccs_write_memory
data: (size = 4)
 0000000F
ccs_write_memory; ccs_error = 0; duration=3 ms
ccs_read_register
index = 200005
count = 1
size = 4
value: (size = 4)
 80230032
ccs_reset_to_mixed
chain_pos: (size = 5) { 0 (halt) 1 (halt) 2 (halt) 3 (halt) 4 (halt) }
ccs_reset_to_mixed; ccs_error = 39; duration=782 ms
Error message: p2040: Core not responding
ccs_reset_to_mixed
ccs_reset_to_mixed; ccs_error = 39; duration=779 ms
ccs_reset_to_mixed
ccs_get_subcore_error
serverh = 0
cc = 0
error = 5
chain_pos = 0
ccs_get_subcore_error; ccs_error = 0; duration=3 ms
serverh = 0
count = 1
ccs_delete_cc
serverh = 0
count = 0
ccs_delete_cc; ccs_error = 0
ccs_kill_server
serverh = 0
ccs_kill_server; ccs_error = 0
5 回复数
6,179 次查看
harryz
Dear YipingWang,
Sorry!  How to use hard-coaded RCW?
Thank you!
6,174 次查看
harryz
Dear YipingWang,
Now, I want to use a JTAG configuration file to override RCW.
My steps and result see the attached file.
Thanks you .
Harry zhang
6,140 次查看
yipingwang
The device can be initialized with a hard-coded RCW option, selected by the
cfg_rcw_src[0:4] configuration inputs.
The following table describes hard-coded RCW configuration options.
For details, please refer to P2040 Reference Manual.
6,184 次查看
yipingwang
Please refer to page 6 in attached PPT about JTAG hardware design.
Please ensure HRESET not tied to TRST, HRESET to the processor exclusive to COP/JTAG header.
Please use hard-coded RCW.
6,180 次查看
harryz
Dear YipingZhang,
  Thank you for your reply!
    My board uboot had been programed before, And the board uboot  had  booted successfully.
I just have a mistake  to override the uboot with a wrong uboot.bin file .  As a result, my board can't boot.   So ,I want to program the flash with a correct uboot.bin again.  Always shows " Failed to  reset the target".
   I'm looking forward to your reply again.
Thanks a lot.
Harry Zhang
