Error message: Core not responding
rb60
I am attempting to program the boot flash on a MPC8543 PowerPC based switch that was corrupted during a firmware upgrade...
I am unable to execute the target task to program the flash because the execute task button is not enabled (it is grayed out).
By turning on logging I see that the probe is passing self test and is able to scan the JTAG bus and see the processor, however it is reporting the following error:
      coreh = [serverh:0;cc_index:0;chain_pos:0]
      mode = 4
      ccs_core_run_mode; ccs_error = 5
Any help would be appreciated. In searching  for answers I see that others have encountered this message, however even though some have marked the issue as solved, they have not posted the solution...
yipingwang
Would you please attach the whole CCS log?
Do you use CodeWarrior for PA 10.5.1?
