CW debug fail..
CW debug fail..
2,099 次查看
wei_w_he
Dear Officer,
We are using HCS12G serials to do the motor control project and I have installed the CW 5.1, but facting the problem when doing the debug by clicking on Debug button, the error message will shows:
Error starting external debugger. Process Error Code 740 (0x2e4)
The requested operation requires elevation.
Could you advise if I miss some installation?
Thanks nad best regards
He Wei
2,010 次查看
BlackNight
Can you try running CodeWarrior in administrative mode, just to see if this solves this problem?
I hope this helps,
Erich
2,010 次查看
wei_w_he
Dear Erich,
I select he IDE.exe and right click and select "Run as Administrator" , but still got same error. (But it didn't prompt to enter Admistnittraor passpord),  Any things I could miss?
Thanks and best regards
He Wei
2,010 次查看
wei_w_he
Dear Erich,
I am using Windows 10 Pro, that could be issue?
I try to set the IDE.exe property Compatibility: Run this program in compatibility mode for Windows 7 or 8,  then the debug menu can come out for while then crash and disappear again after while..
He Wei
