CW 10 debugger mouse hover
1,832件の閲覧回数
wba
In CW10 debugger, if I hover the mouse over a variable it shows the value.  How can I change the display format (ie a char variable to  show the hex value instead of the ascii char)?
1,665件の閲覧回数
Jorge_Gonzalez
Hello Bruce:
I think that is not possible. The format for the hover is always Decimal or ASCII in this case. You can change the display format but only for the Variables view (at upper right corner). Check the next tutorials that might be useful for you:
Hovering and Debugging | MCU on Eclipse
Debugging Variables in Hexadecimal with Eclipse | MCU on Eclipse
Regards!,
Jorge Gonzalez
