68332 bdm
68332 bdm
2,975件の閲覧回数
kong4552
I need to upgrade a 20 years old design based upon 68332 to use latest SMT components. To help debugging the new hardware, I need the background mode software that I used to have using BDM assembly language compiler and debugger  environment running under DOS. Can you help me to locate that piece of software? Thank you
2 返答(返信)
2,076件の閲覧回数
pks00
I've had a lot of success programming BDM devices using uPad with you can find at    https://www.nongnu.org/micropad - I haven't tried it with the 68k, but it works super for several other devices such as HCS12Z - and it looks as if it can be easily adapted to suit your needs if it doesn't work first shot.   Apart from its flexibility, the great thing about it in my opinion is that you don't need to learn a complex user interface to do a simple job like flashing a chip.
2,076件の閲覧回数
ZhangJennie
Please find the tools that can support 68332
MC68332|32 Bit Microcontroller (MCU)|NXP
Jennie Zhang
