How to Fix printf("%f) issue in CW 10.6 or CW 11.0?
已解决
跳至解决方案
1,264 次查看
tholkapiyanv
How to solve following Problem?
   float  a = 5.628;
   printf("\n A Value :%f",*a);
Output:
A Value : f
i tried CW10.6 and CW 11.0
Project Setting  Changed but doesn't work.
( Project --> Properties --> C/C++ Build --> Setting --> Librarian --> Print Formats int_FP )
how to fix this issue?
Kindly anyone give me the solution.
Thanks & Regards,
V.Tholkapiyan
标签 (1)
标记 (1)
1 解答
1,088 次查看
tholkapiyanv
Hi Erich Styger,
      Thanks for your reply.
      Hi i got it answer
      use sprintf() function and
      Project --> Properties --> C/C++ Build --> Setting --> Librarian --> Print Formats int_LL_FP
      Project --> Properties --> C/C++ Build --> Setting --> Librarian --> scan Formats int_LL_FP
above changes i got it.
Thanks & Regards
   V.THOLKAPIYAN
在原帖中查看解决方案
1 回复
1,089 次查看
tholkapiyanv
Hi Erich Styger,
      Hi i got it answer
Thanks & Regards
   V.THOLKAPIYAN
