useing RTRT with Codewarrior
2,390 次查看
metro
hello,
I am trying to use RTRT with Codewarrior for C++. Is there any special flag settings needed in this case. Can i use the same C flags for C++ also?
Hope you can give some insight.
Message Edited by CrasyCat on 2007-09-24 09:04 AM
1,167 次查看
CrasyCat
Specialist III
Hello
I am not sure what RTRT is?
What are you trying to do here?
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
  To retrieve that info:
    - Start CodeWarrior
    - Select Help -> About Freescale CodeWarrior
    - Click on "Install Products"
    - CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
