i.mx31
i.mx31
4,050 次查看
RK
Hello everybody,
             I want to know which IDE from freescale will support I.mx31 (Both Assemblly & C language). And where i can download this IDE. PLZ PLZ  Reply Soon, Thank you..
标签 (1)
3 回复数
1,534 次查看
CrasyCat
Specialist III
Hello
Freescale does not provide CodeWarrior tools for ARM i.mx31.
If you are looking for development tools for this CPU, check our product web page:
Click on the "Design Tools" tab and you will see a list of compiler/debugger provider.
Also ARM may have something available. So You can also check directly with ARM which tools they have available and whether it supports i.MX31.
I hope it helps.
CrasyCat
1,534 次查看
RK
thanx u. Can give some idea that which ide is available in free download that support i.mx31 or i.mx21.
again thank u  a lots. bye
waiting for reply....
nishi
1,534 次查看
Voxan
your best bet would probably be the GNU tools.
you may want to check on the community forums.
Those tools can probably be integrated into eclipse IDE too...
Hope this helps...
Cheers
