how to run custom script after sucessfull target build, CW S12
1,678 次查看
grzegorzK
I use Codewarrior for S12 as shown on picture below
I would like to run batch script after target build, is a proper way to do this?
Maybe something in burner script?
I did not find dedicated properties for this in settings of target.
Best Regards
/Greg
1,463 次查看
ZhangJennie
The HC12 makefile sample code can be found in
{your CW install directory}\(CodeWarrior_Examples)\MakeFileSample_HC12.
  This sample code is available for all HC(S)12 derivatives.
please also search tn100 on freescale web site which is about how to implement CW in batch mode
4 回复数
1,463 次查看
ZhangJennie
can you please specify what do yo want with this script?
1,463 次查看
grzegorzK
run user script (command line) what for example will be parse output hex file and prepare report.
1,464 次查看
ZhangJennie
1,463 次查看
grzegorzK
not applicable in my case, I do not use makefile to manage project under CW
