dsp56802  - error on write PLLCR
1,911 次查看
MBC
Hello, I am a beginner. I encountered a problem when performing code. Please help to fix this.
When step-by-step debugging code in the debugger an error occurs: "Error occured while trying to step the target out of an address range"
F_EntryPoint:
        orc     #4096,X:IPR
        move    X:GPR15,X0
        andc    #-769,X0
        orc     #1024,X0
        move    X0,X:GPR15
        orc     #61440,X:PLLCR
        orc     #64,X:DFIU_CNTL
        move    X:$103f,X0
        move    X0,X:ISOCTL
        andc    #65471,X:DFIU_CNTL
        andc    #65531,X:PLLCR
_L8:
        bftstl  #4,X:PLLSR
        bhs     _L8
        movei   #129,X:PLLCR
        movei   #0,X:CLKOSR
        movei   #8487,X:PLLDB
_L12:
        bftstl  #32,X:PLLSR
        blo     _L12
        movei   #130,X:PLLCR
        ;on this step occured error
        ;after this PLLCR takes value 17 (decimal)
        jmp     Finit_56800_
        rts
标记 (1)
797 次查看
trytohelp
This is not easy to determine the cause of the problem.
The better way will be to log it directly in the Technical support system.
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - You can submit your request through the web from there.
Please provide us more details about the Tool version used.
To do that you must:
* CW:
Start the IDE and click on Help | About Metrowerks CodeWarrior.
Click on Installed Products
Provide us all info displayed.
Or you can save them in a txt file.
Can you please provide us your example reproducing the issue ?
Pascal
798 次查看
trytohelp
* CW:
Pascal
