compiling error
compiling error
4,342 次查看
pallav
if i get my code size >1024 byte it give tthat it is more then 1024 so cant compile plz help me where to set i have initialy set the model tiny is this a prob plz help me how to resolve this prob
best reards
pallav aggarwal
1,963 次查看
Andrew
it is probably a license error: CW doesn't find the file "license.dat". Are you working in a Remote Desktop Connection with XP? In this case CW search the license in a wrong directory!
Bye
1,963 次查看
BlackNight
another hint is that you check your license settings. For this simply launch the compiler in the prog directory (e.g. chc12.exe for the HC12 compiler), and then check the diagnostics in the about box (Help > About).
Erich
1,963 次查看
CrasyCat
Specialist III
Hello
which processor are you targeting (HC08, HC12, ...)?
Which version of CodeWarrior are you using? To get that info:
  - Start IDE
  - Select Help -> "About Metrowerks CodeWarrior"
  - Click on "Installed Products" button.
Version you are using is indicated on the top part of the dialog.
CrasyCat
