Switch/Case Statement debugging / tracing
5,258 次查看
zdjohnson
Case statements are apparently optimized down to a jump table which prevents me from setting a breakpoint onto a particular case in the switch statement.
1) How can I set a breakpoint to a particular case in a switch statement?
2) How does one change the level of optimization applied in the compile step or set options like bounds checking etc?
Thanks for any help.
David
4 回复数
4,911 次查看
ZhangJennie
what chip and CW version do you work with?
Zhang Jun
4,911 次查看
zdjohnson
I am using CodeWarrior CW_MCU_V6_3_SE with Freescale MC9S08QE64 (HCS08).
David
4,911 次查看
ZhangJennie
hi,
1. we can't set a breakpoint as specific code  such as case 0:.
here is a piece of disassemble code i extracted for switch...case
we can see there is no "real" disassembly code allocated in memory for "case 0". so it's not possiable to set a breakpoint at this line.
2. CW for HCS08 doesn't define a optimization level. but we can disable optimization in compiler option settings
can this help you?
Zhang Jun
4,911 次查看
zdjohnson
Thank you for your reply.  I see what you mean.
David
