Relative includes in Codewarrior 10?
2,635 次查看
admin
Specialist II
How can I get Codewarrior 10 to work with includes such as:
#include "../common/moptions.h"
I know the file exists at the specified location, but the compiler doesn't seem to be following the path relative to the current file...
Brad
2,024 次查看
CrasyCat
Specialist III
Hello
Look at option -cwd and -gccincludes in {Install}\Help\PDF\MCU_ColdFire_Compiler.pdf
These options might be helpful.
CrasyCat
4 回复数
2,024 次查看
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, Coldfire V1, ..)?
CrasyCat
2,024 次查看
admin
Specialist II
Coldfire V2
2,025 次查看
CrasyCat
Specialist III
Hello
CrasyCat
2,024 次查看
admin
Specialist II
Worked great, thanks!
