Multiple file search
已解决
跳至解决方案
1,556 次查看
bob_s
I am running CodeWarrior 8.2.3 in Win7 32bit.  Since I've installed on Win7 I haven't been able to do multiple file searches.
I thought it might be Win7 file indexing so I installed Windows Virtual PC and Windows XP mode.  I've opened projects both in the standard Win7 partition and in the Virtual PC partition and still cannot get the search option to search multiple files.
The search window pops up, but the search select buttons are grayed out and don't respond.
Any help would be appreciated.
Bob
标签 (1)
标记 (1)
1 解答
1,162 次查看
bob_s
I've located the issue.  The tabs in the lower half of the search window had been set to folders and there were no folders selected in my new installation.  I got used to expecting the path to be there and forgot to reinitialize it.  I was too focused on the programming.  :smileysurprised:
在原帖中查看解决方案
1 回复
1,163 次查看
bob_s
