Porting code to CW.
Porting code to CW.
2,434 次查看
Vianney
I have the job to port a Cosmic code to a CW code. The microcontroller used is principally the HCS08GT32 but it can also works with other devices.
Like I never do that, i wondered if someone can give me some advices...
Vianney
1,022 次查看
CrasyCat
Specialist III
Hello
Go to the Freescale CodeWarrior for HC08 Web page
Under Featured Document you found 8/16Bit Tech Note
After you extract the PDF from the zip file look at TN234.pdf.
If provides some advice on porting Cosmic code to CodeWarrior.
I hope that helps.
CrasyCat
1,022 次查看
Vianney
Yes, it helps me so much, thanks.
I am doing the job and I hope it will ending as it begins, i.e., in a good way.
Bye.
