Any 16-bit FFT library for SC140?
2,336 次查看
dspuser
Hi all,
I'm looking for a real input FFT/iFFT C- library optimized for SC140 DSP.
I found an old package for FFT and iFFT but I also found coding bugs in them, hence
my confidence level in them has dropped. I would like to avoid writing one myself (or
debugging a library) if an optimized (and updated) C library is already available.
Thanks for all leads,
Mihran
标签 (1)
1 回复
995 次查看
J2MEJediMaster
Specialist I
Try using the keyword search feature (it's located at the upper right of this web page) and enter "SC140 FFT". You may find something of use for your application. Sorry I can't be of more help on this. I've searched Google and although there are FFT libraries out there written in C, none are optimized for the StarCore processor.
---Tom
