Error encountered using VECTOR ADDRESS in PRM file
e_taylor
Hello, I am trying to implement an interrupt routine on an XDP512 using CW 5.1 and get an error indicating there had been an overflow or underflow of the vector value.
There is a file named Vector.asm that has the following code:
;VectorTest
         XDEF SVC_RTI
SVC_RTI rti
At the end of the PRM file I added:
VECTOR ADDRESS 0xFFF0 SVC_RTI
What have I done incorrectly that is causing this error?
Thank you!
Ed
ZhangJennie
Hi @e_taylor
Please send your error screenshot. a demo project is better. Thus I can look into it directly.
Jun Zhang
ZhangJennie
Hi @e_taylor
Jun Zhang
