CodeWarrior Debugger Callstack
3,464 次查看
ignisuti
I'm using CW10.2 on a Windows 7 64-bit machine
At some point, I had a View in my Debugger that showed me a Callstack. It was called something else and I can't seem to remember what it was called.
Does anyone know. I really miss it...
7 回复数
3,090 次查看
CrasyCat
Specialist III
Hello
    Inside of Eclipse you usually see the call stack in the Debug View
CrasyCat
3,090 次查看
ignisuti
Yes, that's correct, but I closed that window at some point and can't remember what it was called.
3,090 次查看
CrasyCat
Specialist III
Hello
In order to re-open it:
    - Select Window > Show View > Other.
    - Expand the Debug tree
    - Click on Debug.
CrasyCat
3,090 次查看
ignisuti
Yes, that didn't do it. The Debug Perspective USED to have the Callstack VIEW. Only it wasn't called Callstack, it was called something else that I can't remember.
Resetting my Debug Perspective doesn't help because I've saved the Debug perspective after I closed the Callstack view. Hindsight makes me really wish I hadn't done that, but it should be easy to get the Callstack back if I only knew what it was called.
3,090 次查看
CrasyCat
Specialist III
Hello
    I have no clue which view you are talking about here.
   I am always getting the Call stack inside the Debug View.
    Did you consider creating a new Workspace and importing your project there?
    This should allow you to return back to the default layout for the debug perspective.
    To create a new workspace, select File > Switch Workspace > Other and browse for a new workspace location.
    This way you should be able at least to retrieve the name of the view you are looking for.
CrasyCat
3,090 次查看
ignisuti
CrasyCat, you were right all along. I was getting something confused.
Please accept my sincere apologies.
3,090 次查看
CrasyCat
Specialist III
Hello
No problem. I am glad you get up and running again.
CrasyCat
