CW 10.1 - How to break debugger when variable changes
ignisuti
I’m using the Multilink Universal debugger with a 6-wire BDM cable to debug a MCF51CN128 Coldfire MCU.
How can I get the debugger to 'break' on the line of code causing one of my variables to change values?
CrasyCat
Specialist III
Hello
    I am not an expert on MCF51CN128, but for other MCUs I used watchpoints for this purpose.
    To set a watchpoint:
          - In the Variable Windows display the variable you want to track
          - Click right on the variable name and select watchpoint
          - Adjust settings of the watchpoint to whatever you want to track.
          - Click on OK.
  Note that watchpoint may not be supported on all MCUs as it requires some HW resources to function properly.
  But it might be worth a try.
CrasyCat
