Boot load settings in cmd file - problem with xBootCfg
EliArad
Fresh Out Contributor
in the document Serial Bootloader for 56F82xx
it says to add the following in the cmd file of the application firmware side.
.xBootCfg(RWX):smileysurprised:RIGIN = 0x00007BFE,LENGTH = 0x2
.ApplicationConfiguration :
# Store the application entry point
WRITEH(F_EntryPoint);
# Bootload start delay in seconds
WRITEH(10);
} > .xBootCfg
When i add this and trying to compile i am getting an error:
linker error on this line:
Can you please tell me what should I do?
Eli
EliArad
hi
Can any one from freescale can send me please a copy  example of
smm_pROM_xRAM.cmd that works with bootloader?
I did all it says in the document and it failed to link
like in the previuos message.
please send to easp13
at
gmail.
com
Eli
