64 bit systems
64 bit systems
1,104件の閲覧回数
TomIrvine
I am trying to run Codewarrior for the HCS12 in a 64 bit system, and I keep getting an error
that iit is not compatible, anybody know about a way around this
933件の閲覧回数
kef
Specialist I
CW6.3 for MCUs is not CW for HCS12. CW5.1 for S12(X) installs and operates on 64bit windows quite well. Though it is recommended to install it not to Program Files folder, which Win7 is trying to make read only like, remapping ini and some other files to %user%\AppData\Local and LocalLow. This may make CW half working, so try different root folder.
