GHS and DIAB Compiler
8,962 次查看
suhas
We are trying to use AUTOSAR on DEVKIT-MPC5748G with S32DS IDE & EB Tresos Studio MCAL Configuration.
We are following "Release Notes for MPC574XG AUTOSAR 4.0 MCAL RTM 1.0.5" and "Introduction to NXP AUTOSAR MCAL Software | NXP ", and we are facing issues:
1. The release notes suggest using "Green Hills Multi 6.1.6 / Compiler 2014.1.6" or "Windriver DIAB DIAB_5_9_4_8" Compilers, But we are not able to find a link to download these compilers and is it available for free?
2. After Compiling the code can we debug using the Onboard OpenSDA debugger and S32DS IDE?
Thanks & Regards
SUHAS S
4 回复数
6,353 次查看
Suzensah
I have especially been keeping track of the article, and I anticipate deriving a lot of value from it. Following that, I want to thank you for sharing it.
DGme Employee Login
6,944 次查看
Bessieswsa
We use GHS Standard Mode internally to develop our own tools. Double Check, Green Hills Software's integrated static analyzer, allows you to identify programming errors even before running your program and find bugs that may never show up during regular testing. DGME Employee Portal
7,295 次查看
Bessiesw
I'm especially stayed aware of the article and I will get many benefits from it. Subsequently, thank you for sharing it.
8,920 次查看
mariuslucianand
Hello @suhas ,
This community space tries to respond to questions related to the Model-Based Design Toolbox that generates code from the Matlab and Simulink environment.
Please create a new thread on the MPC5xxx space or new NXP support case according to the following procedure: https://community.nxp.com/docs/DOC-329745
Hope this helps,
Marius
