freescale Motorola Type XC68705S3CS
4,719件の閲覧回数
francoisracordo
Hello you have the Datasheet for freescale Motorola Type
XC68705S3CS
4 返答(返信)
4,531件の閲覧回数
RadekS
Hi Francois,
XC means prototype version.
I just found 68HC705SR3 type.
http://www.nxp.com/pages/microcontroller:68HC705SR3?
Could you please check whether maskset is printed on your MCU?
It should be 1F10W (or 0F10W) in case of 68HC705SR3 type.
Are there any other labels on your MCU?
I hope it helps you.
RadekS
4,531件の閲覧回数
francoisracordo
Hello thank you for the answer
the exact reference on the motorola is on the photo thank you for giving me a dataset that is compatible thank you for your help
Greetings François Racordon
4,531件の閲覧回数
francoisracordo
4,527件の閲覧回数
RadekS
Hi Francois,
Thank you for sharing picture and datasheet.
Your datasheet (in attachment) looks correct for these MCUs (maskset 1TJ6). We just found also addendum to this datasheet.
Note: I suppose that you need datasheet for some special MCU birthday celebration. ;-)
MCU was produced in sixth week of 1986. So, soon it will be 30 years….
Please present our regards…
RadekS
