error using free bdm board whil compilling a jm60
1,239件の閲覧回数
rodricasas
Hi everybody, I have a problem with a single proyect when  I  Try to load the code in the jm60 mcu I get this error: "parameter file could not be loaded in freescale (C:\Program Files\Freescale\CodeWarrior for Microcontrollers V6.3\prog\fpp\mcu1301.fpp).
I looked for the archive and i could not find it, can ahybody help me with this??
813件の閲覧回数
peg
Senior Contributor IV
Hello and welcome to the fora, rodricasas.
What interface do you have selected?
It seems you are using the OSBDM adapter from your post but the fpp file causing the error I think is for the P&E Multilink adapter.
