UART's commands for a RS08 microcontroller
colargol8
Hy, I am newbie in microcontroller, I am looking for a UART's commands for a RS08 microcontroller and way to use it.I have a MC9RS08KB12. Can you help me?
Tags (2)
vicentegomez
Please check the following application note, almost all the peripherals for the RS08 are the same than the S08, so you can use this document as good start point
https://www.nxp.com/docs/en/user-guide/HCS08QRUG.pdf
software (this is old, but use it as reference)
https://www.nxp.com/docs/en/user-guide/QE128QRUGSW.zip
also check
HS908SH8 - SCI module wrong data transmited/received
https://community.nxp.com/thread/302646
The RS, SH and the QE has the same SCI module
I hope this will help you
Take care
