Secure device erased. Do you wish t...
4,142 次查看
employee
Hi,     I would like to send you my problem with erasing of Flash memory MCU. 1. I erased memory and communication with MCU was shuting down during erasing. 2. When I did erasing again I was get the message: Sorry for my english. Thank you very much for your answers. Petr
Message Edited by employee on 2007-08-13 07:11 PM
doc11.doc
Message Edited by t.dowe on 2009-10-27 02:00 PM
5 回复数
1,950 次查看
employee
Problem is resolved. The pins 15-16 was interconnected.MCU is OK. MCU was erased and programmed.
Petr
1,950 次查看
peg
Senior Contributor IV
Hi employee,
Aside from the shutting down, this is normal.
What happens after you click Yes?
1,950 次查看
employee
When I press Yes, the programming algorithm was only reloaded. The MCU Flash memory wasn't erasing.
Thank you very much.
Petr
1,950 次查看
peg
Hi again,
The Blank check fails? What is the message?
Do a Upload Module and what do you get? Just a one line s19 file or a very big one?
1,950 次查看
employee
I'm going to answer afternoon when I will arrive from work. I'm going to send printscreens during erasing and programming. I have the other MCU and this MCU is OK for the same program modul.
Thanks.
Petr
