S08PA - if it possible to flash the device via HEX file
1,566 次查看
shai_b
Senior Contributor II
Hi Team,
My customer is planning to build a probe to the mass production line and they need to have an Intel HEX format (*.hex).
Does mc9s08pa support programming via *.hex, if yes, how I can convent the *.s19 into *.hex?
Please advise back, Thanks in advance.
Kind regards,
Shai
标记 (3)
1,550 次查看
shai_b
@vicentegomez  Hello,
Thanks for your feedback, but your provided link has a non-working link inside.
so research it on google and found a proper link to share.
https://mcuoneclipse.com/2012/09/27/s-record-intel-hex-and-binary-files/
hope it would help others as it helped me.
Have a great day.
Shai
1,558 次查看
vicentegomez
Please check the following link:
https://community.nxp.com/t5/CodeWarrior-Development-Tools/CodeWarrior-create-s19-hex-bin-for-s08/td...
I hope this will help you
Have a good day
1,551 次查看
shai_b
Have a great day.
Shai
