Reset when the log () function is executed;
3,703 次查看
agarcia
I am working with the MC9S08PT16VWJ microcontroller when I execute the following instruction:
b = (float) log ((double) c);
A reset occurs on my card when the value of c is greater than 150, I have wachDog disabled.
What I can do?
3,632 次查看
kef2
Senior Contributor V
Floating point support requires more stack space. Try increasing STACKSIZE in PRM file.
3,633 次查看
kef2
3,625 次查看
agarcia
yes, it already worked by default it has 80H increases it to 100H and it worked correctly
3,672 次查看
vicentegomez
Can you please check the SYS_SRS register
I am thinking that you are running out of memory
Have a good day
