Reset when the log () function is executed;
3,801件の閲覧回数
agarcia
I am working with the MC9S08PT16VWJ microcontroller when I execute the following instruction:
b = (float) log ((double) c);
A reset occurs on my card when the value of c is greater than 150, I have wachDog disabled.
What I can do?
3,730件の閲覧回数
kef2
Senior Contributor V
Floating point support requires more stack space. Try increasing STACKSIZE in PRM file.
3 返答(返信)
3,730件の閲覧回数
kef2
3,723件の閲覧回数
agarcia
yes, it already worked by default it has 80H increases it to 100H and it worked correctly
3,770件の閲覧回数
vicentegomez
Can you please check the SYS_SRS register
I am thinking that you are running out of memory
Have a good day
