Programming with Command Line
2,642 次查看
edasanli
I have a MC9S08PA4 microprocessor. I need programming with command line. Does anybody have a solution about this? I prefer Linux but i can use Windows too if i have to.
Thank you,
Eda SANLI
2,632 次查看
vicentegomez
You can use the command line on codewarrior 11.x for that.
2,623 次查看
edasanli
If you have, can you please share some examples about that? I used CodeWarrior Flash Programming from a DOS shell. I created a tcl file and I used it with -vmargsplus command. But i need to do flash programming witout opening CodeWarrior IDE.
With my best regards.
2,613 次查看
vicentegomez
Sorry I only do it with codewarrior.
