Is it possible to copy the contents of one controller to another
1,984件の閲覧回数
matrixmm
Hi, sorry for the stupid question.
Is it possible to copy the contents of one controller to another.
I have the same two boards. One is working and second broken. I repaired the second board and replace burned HCS08 controler with new one.
The question is, can I somehow copy the content from a working controller to a clean one?
using USBDM for example?
any help will be appreciated
3 返答(返信)
1,935件の閲覧回数
matrixmm
I solved. If someone has a similar problem, it can be easily done using USBDM Memory dump. Rip flash to a file and upload with FlashProgrammer to a new chip.
1,969件の閲覧回数
vicentegomez
If the original firmware is not protected, yes you can perform an "attach" on CodeWarrior using the multilink.
1,942件の閲覧回数
matrixmm
I try program one chip and clone to another. Just for learning.
It's not protected. In codewarrior i choose MAC Tools -> Attach to target. But not have USBD programmer to choose. :(. Whats i do wrong?
Any help will be apreciated.
