Is It possible to use MC9S08LG32 development board to programme other MC9S08LG32 based hardware
1,162件の閲覧回数
ashishgholve200
Hello everyone , i want to know can we use MC9S08LG32 development board to programme other MC9S08LG32 based hardware and how much reliable is that
3 返答(返信)
1,044件の閲覧回数
donw
I don't know about your board, but I guess its similar to the DEMOJM60 board I use
To program external CPU boards,
I simply remove the CPU and extend out the BDM and ground wires to the extranel target CPU
(you could also bring out the RESET wire to avoid having to do a manumal target reset)
1,044件の閲覧回数
ashishgholve200
Thanks but unfortunately i have demo board of 9S08AW60E so i want to ask whether the above mentioned procedure is applicable here also with this 9S08AW60E demo board or not. I feel confused because of your statement "remove cpu" . Can you elaborate on this . It will be thankful if you give me step by step procedure.
1,044件の閲覧回数
bigmac
Specialist III
For the DEMO9S08AW60E board, a 6-pin header would be soldered to the unused J32 location.  A 6-way ribbon cable assembly then connects from this header to the header on the target board.  The resident MCU on the board needs to be removed from its socket, to prevent conflict with the target board.
Mac
