In Circuit Programmer - Debuger for MC9S08DZ32
2,832 次查看
BlueTower
HI! I am interested in using the MC9S08DZ32 chip cause my project involves CAN interface.
I would like to do in-circuit programming and debugging. Is there a tool available to do the job?
4 回复数
2,499 次查看
JimDon
Senior Contributor III
You can use a USBDM. You can buy one here:
Wytec USBDM
2,499 次查看
BlueTower
Hi. I am interested to find out the conections on my target board. I mean which pin of the
microcontroller is used for the debugging and how is connected to the target header?
2,499 次查看
JimDon
Please refer to section 2.2 "Recommended System Connections" found in the MC8s08DZ "Data Sheet".
MC9S08DZ60.pdf
2,499 次查看
Mickey
Might consider this ultra-small USBDM.
USBDM JS16
Connection to target board throught standard 2-row 6-pin 2.54mm pitch.
