How to take a read of ADC10 Pressure or Temperature in a FXTH8709DT1
1,182 次查看
davidramirez
I read about a firmware inside of a FXTH87XXDT1, But i´m new in this products and I´m learning abut this sensor, but I know a little programm on Codewarrior but i can´t see ADC register in this sensor then I assume that this function is only availabe on firmware.
I want read temperature and pressure and see the register and debbuger on BDM.
I download the started program but i cant understand because read all of this sensors is transmit for RF this result.
I have the simple code.
Thanks.
Original Attachment has been moved to: FXTH_V1.txt.zip
975 次查看
davidramirez
I found the answer.
I have FXTH871511 Sensor and I create the jump table like in the datasheet.
And i can access to Firmware zone table and all its ok.
Thanks.
976 次查看
davidramirez
I found the answer.
Thanks.
