I read about a firmware inside of a FXTH87XXDT1, But i´m new in this products and I´m learning abut this sensor, but I know a little programm on Codewarrior but i can´t see ADC register in this sensor then I assume that this function is only availabe on firmware.
I want read temperature and pressure and see the register and debbuger on BDM.
I download the started program but i cant understand because read all of this sensors is transmit for RF this result.
I have the simple code.
Thanks.
Original Attachment has been moved to: FXTH_V1.txt.zip
