Detecting Usb Enumeration error
1,835 次查看
elettro86
Hi guys,
I am developed USB device protocol. My stack work fine and the device is correctly enumerated by the host. I assume that the enumeration process is correctly terminated when a set_configuration is send by the host, so I have "an event" in order to detect when the device is correcly enumerated.
But if the enumeration failed, how I can detect this error? I could use a time-out (if a set_configuration is not receive in 10sec i.e.) but it it is potentially dangerous, I could assume uncorrect decision based on my time out.
Can anyone help me?
Sorry for the bad English
King Regards
Francesco
标记 (2)
1,435 次查看
CarlosCasillas
Hi Francesco,
The enumeration time may vary depending the Host (and its Operating System). On the following link you could find some useful information regarding enumeration process on Windows:
http://blogs.msdn.com/b/usbcoreblog/archive/2009/10/31/how-does-usb-stack-enumerate-a-device.aspx
Additionally, you may find additional information at the following thread:
https://community.freescale.com/message/107572
Hope this will be useful for you.
Best regards!
/Carlos
