EVB9S08DZ128 eval board with codewarrior 10.4
已解决
跳至解决方案
1,335 次查看
martinlockner
I need help getting Codewarrior 10.4 to interface (debug mode) to an EVB9S08DZ128 eval board, the Softec driver does not find codewarrior 10.4. Has anyone solved this issue?
标签 (1)
1 解答
1,193 次查看
ZhangJennie
Do you use win7 platform? the softech interface doesn;t support win7.
if your windows is win7, please use external P&E BDM multilink cable to connect the board
在原帖中查看解决方案
1 回复
1,194 次查看
ZhangJennie
